Where are the drain plugs on my komatsu d37p
   / Where are the drain plugs on my komatsu d37p #1
Cplum98
Komatsu d37p
I need to drain the oil from the dozer from the drives. Is there an access point underneath?
   / Where are the drain plugs on my komatsu d37p #2
Welcome to TBN. :)
   / Where are the drain plugs on my komatsu d37p #3
WELCOME to TBN :)
I moved your thread to the Construction Equipment Forum.
Thank you, there are three dipsticks under seat, I assume these are the drive reservoirs. Sae 30 oil goes in it. So the drain for these is underneath? Thanks
   / Where are the drain plugs on my komatsu d37p #7
Don't know if I'd want to use SAE 30 in the final drives. Are you sure those dipsticks aren't for the steering clutches and differential?
What does your manual call for?
I don't have a manual. Hence the message post. It may be the steering clutches. The middle one has some water in it though and I need to drain it. Any advice?
   / Where are the drain plugs on my komatsu d37p #9
Get a manual - really. I am not trying to be wise.
   / Where are the drain plugs on my komatsu d37p #10
The middle one is not the final drive. The final drives are outboard of the steering clutches.
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
