Where are the drain plugs on my komatsu d37p
   / Where are the drain plugs on my komatsu d37p #1
Cplum98
Komatsu d37p
I need to drain the oil from the dozer from the drives. Is there an access point underneath?
   / Where are the drain plugs on my komatsu d37p #2
Welcome to TBN. :)
   / Where are the drain plugs on my komatsu d37p #3
WELCOME to TBN :)
I moved your thread to the Construction Equipment Forum.
Thank you, there are three dipsticks under seat, I assume these are the drive reservoirs. Sae 30 oil goes in it. So the drain for these is underneath? Thanks
   / Where are the drain plugs on my komatsu d37p #7
Don't know if I'd want to use SAE 30 in the final drives. Are you sure those dipsticks aren't for the steering clutches and differential?
What does your manual call for?
I don't have a manual. Hence the message post. It may be the steering clutches. The middle one has some water in it though and I need to drain it. Any advice?
   / Where are the drain plugs on my komatsu d37p #9
Get a manual - really. I am not trying to be wise.
   / Where are the drain plugs on my komatsu d37p #10
The middle one is not the final drive. The final drives are outboard of the steering clutches.
2019 Freightliner M2 106 26FT Box Truck (A51692)
2019 Freightliner...
Kubota ZG327 (A50120)
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
