When to replace chainsaw file
   / When to replace chainsaw file #21
if the cutting teeth are not work hardened , you can get a lot of mileage from 1 file.... but as it gets used, it takes a bit more each time to do a good job .... BTW, stopping frequently and touching up the teeth can actually extend the life of the chain too....
anyway , do what you "feel" is best for you ... 3 strokes , 10 strokes... all personal preference .... and experience .... some need more , some less ...
just try not to work with a dull tool of any sort.... just makes things harder and longer to do.:)
Teeth get "Work hardened"? Does this happen? Or are chains tempered (softened) when they are over-heated and slowly cool?
   / When to replace chainsaw file #23
I do what has already been mentioned over a few posts:
--buy them by the dozen and don't try for too much mileage
--I use a holder to judge the angle and mark the handle end. Normally get about two sharpenings before turning it 90 degrees for another two for about 4 sharpenings per file.
I also have to resist the tendency to over-use sandpaper disks. At some point it becomes counter productive, even at $0.00 per hour!
   / When to replace chainsaw file #24
the dull teeth get very hot then cool quickly when you stop ( chain sitting in a big steel bar heat sink ... remember ) .. the tips get very hard and you actually need a stone to sharpen them afterwards .... .... stopping before it gets dull (and hot ) keeps the teeth softer and easier to file ....
Very interesting. Good info. :thumbsup: I think we've moved beyond Chain Sharpening 101 and are learning more advanced Chain Sharpening 213 info.
   / When to replace chainsaw file #26
I don't know if you can go by me as I was strictly into production. When I was working, I'd use a file 6 times. This included touch ups and occasional ding repairs. To this day as a regular homeowner, I still use it to file 6 times. I just like the cut going faster with a few strokes rather than too many multiple strokes to get to the same place.
   / When to replace chainsaw file #27
:thumbsup: ding or dong , touch the ground /rock , etc ... stop and touch up the blade ...
continuing to "cut any way" just costs you more time down the road ....
   / When to replace chainsaw file #28
4-6 sharpenings?! I must have about 25-50 on mine. I guess I've got my money's worth out of it and can afford to splurge $1.45 on another. Heck, maybe even two!
Even when I'm "just going to touch it up", "2-3 strokes each", somehow I end up taking 5-7 on each tooth until it "feels" right. Don't know why I do this. :confused3:
You do it because you are using a dull file. 25 chains, much less 50 are way over the life of a file.
Harry K
   / When to replace chainsaw file #29
With a sharp file you will get the chain sharper, quicker & be more accurate with angles and such.
You do it because you are using a dull file. 25 chains, much less 50 are way over the life of a file. Harry K
Yes! "I see the light" said the blind man. FINALLY grabbed a new file. Wow, what a difference. 3 zips and done.
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2007 CHEVROLET KODIAK C6500 (INOPERABLE) (A55745)
2007 CHEVROLET...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
