When to replace chainsaw file
   / When to replace chainsaw file #31
I replace my chainsaw file when after filing, I'm still cutting feather sawdust.
I replace my chain after filing it about 10 or 12 times, or if I break more than one tooth, which for me is somewhere between 6 and 12 months.
I replace the bar if it gets bent, or a rivet loosens up.
I replace the chainsaw if I blow a cylinder. Haven't had that problem since I stopped buying the El Cheapo light saws made for the occasional user and started buying the larger, 'logging' grade saws.
Only had a cylinder blown on one Husky and that was a factory defect - they replaced it free. Of course I did have to replace one chainsaw that I had pinched when a tree came down and twisted, and just before coming to rest, released the saw and rolled over it, turning it into $500 worth of metal and plastic confetti. Only time I ever cried cutting trees.
   / When to replace chainsaw file #32
Yes! "I see the light" said the blind man. FINALLY grabbed a new file. Wow, what a difference. 3 zips and done.
I hate to think about the many years I spent fighting files before I learned the lesson.
Harry K
   / When to replace chainsaw file #33
I started using these diamond coated burrs about a year ago and am really pleased with how well they work. I have one in a corded Dremel tool in the shop and a second in a battery powered Dremel tool for quick touch ups in the field. They come in a 4 pack and I am still on my first two.
I used to use the Dremel brand "stone" sharpening burrs but they would usually break off tip before getting complete chain sharpened.
4 PC 5 32" Diamond Chainsaw Sharpener Burr Stone File Fits Dremel 1453 | eBay
Sent from my iPad using TractorByNet
   / When to replace chainsaw file #34
With a sharp file you will get the chain sharper, quicker & be more accurate with angles and such.
I agree, it is much easier to keep consistent angles with a sharp file.
   / When to replace chainsaw file #35
After the push, and the feel of the bite I always look at the tooth for a good bite, I also use a file comb on all my files.. best of all they pull double duty by removing lint on Velcro tabs and such..
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
New/Unused Agrotk Tire Changer (A57454)
New/Unused Agrotk...
2021 Bobcat T66 Skid Steer (A57453)
2021 Bobcat T66...
2017 FREIGHTLINER M2 106 (A58214)
2017 FREIGHTLINER...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58216)
PALLET OF 15 4 X 8...
John Deere 5103 (A53317)
John Deere 5103...
