When is the corn finally harvested?
   / When is the corn finally harvested? #21
Ofcourse to check the moisture tester for accuracy you have to take the corn sample to the elevator and compare readings anyway... /forums/images/graemlins/grin.gif
   / When is the corn finally harvested? #22
The link that I provided is for the company that makes the testers for USDA and the ones used at elevators.
Dave
   / When is the corn finally harvested? #23
They still have to be calibrated with a current USDA tested and stamped moisture tester to insure accuracy, they usually don't come out of the box or closet after a year dead on. Easiest thing to do when drying corn to avoid getting docked later is checking your tester against the elevator you're selling to.
From your link, emboldening mine. http://www.dickey-john.com/products/ag/product_detail.php?products_id=96
Featuring ±0.5 repeatability with normal stored grain, this technologically advanced unit lets you easily bias to match readings to local elevator tests. Select grain types with the push of a button, and change grain calibrations with a simple download.
   / When is the corn finally harvested? #24
I don't think I would buy a tester if I was going to use the corn to heat with. Just my 2 cents
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A50854)
2016 WINNEBAGO...
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
71052 (A49346)
71052 (A49346)
SERVICE BODY BED W/CRANE (A50854)
SERVICE BODY BED...
2006 TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
2006 TRAIL MASTER...
