When is the corn finally harvested?
/ When is the corn finally harvested? #21
Ofcourse to check the moisture tester for accuracy you have to take the corn sample to the elevator and compare readings anyway... /forums/images/graemlins/grin.gif
/ When is the corn finally harvested? #23
They still have to be calibrated with a current USDA tested and stamped moisture tester to insure accuracy, they usually don't come out of the box or closet after a year dead on. Easiest thing to do when drying corn to avoid getting docked later is checking your tester against the elevator you're selling to.
From your link, emboldening mine. http://www.dickey-john.com/products/ag/product_detail.php?products_id=96
Featuring ±0.5 repeatability with normal stored grain, this technologically advanced unit lets you easily bias to match readings to local elevator tests. Select grain types with the push of a button, and change grain calibrations with a simple download.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
PALLET OF(3) CABINETS & (5)BOXES OF CARPET SQUARES (A60432)
PALLET OF(3)...
2015 UTILITY 53FT REEFER TRAILER (A59905)
2015 UTILITY 53FT...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
