When is it time to repalce the tires
   / When is it time to repalce the tires #1
marhar
Denton NC
Farm Trac 60
I have a FarmTrac60. It is a 2003 model with low hours (less than 2000 hours). When not used the tractor is parked in a barn that is not climate controlled. I do not use the tractor for my livelihood.
The rear tire are 14.9x28. I have noticed some tread wear but I am more concerned with the cracking I see on the sides of the tire.
I am looking for advice of how to know when I need to replace the tires. One one hand I think about waiting until I have a blow out on the other hand I know that if I have a tire failure it will be at the worst possible time in an area that is not easily accessible.
   / When is it time to repalce the tires #2
Tractor tires usually last decades unless they wear out first. I’d leave them. Chances are they’d start leaking before they suffered a catastrophic failure.
Thank you.
   / When is it time to repalce the tires #4
And when they start leaking, tube them and use them 10 more years.
   / When is it time to repalce the tires #5
That is what I do. I never could guess when a tire will fail. The belts provide strength. If they have enough tread and the tube can hold air use them. I would not run down the road at 15 mph with a bad tire, but in a field at 5 mph the tractor will fall in the dirt.
   / When is it time to repalce the tires #6
I had a Ford 1100 subcompact tractor that had tires on it so cracked it looked like a pond gone dry! I sold the tractor to a friend and he was all concerned about the rear tires, that he was considering backing out of the deal. I found some tires and rims in a junk yard and took them with me when I delivered the tractor, told him not to put them on till he had some sort of tire issue. He didn't listen, just put them on the next week. When I bought the tractor back, he gave me the original tires and rims, and they are still up, considering the fact that they are fluid filled. We are talking about a set of tires that came on the tractor in 1978!!
David from jax
   / When is it time to repalce the tires #7
Just yesterday the front tire sidewall on my Farmtrac 270 DTC blew as my wife was moving manure out to the manure pile. She said it made a hissing sound and she thought a hydraulic hose blew (goats like chewing on them). I told her she'd know right away if it was a catastrophic failure in hydraulic system. The unit is 15 years old with only 350 hours but has been stored outdoors throughout most of its life. Is it possible to insert a tube?
   / When is it time to repalce the tires #8
No
   / When is it time to repalce the tires #9
Get a barn and a new tire. the sun is extremely hard on tires......
   / When is it time to repalce the tires #10
No tube is going to fix that one, she gone!
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A53472)
Adams Load Out...
2005 JLG E300AJP TELESCOPIC MANLIFT (A51246)
2005 JLG E300AJP...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
Engel 20' Boat (A50121)
Engel 20' Boat...
HURRICANE 5' X 10' CONTAINER (A51248)
HURRICANE 5' X 10'...
