When is it time to repalce the tires
   / When is it time to repalce the tires #1
marhar
Denton NC
Farm Trac 60
I have a FarmTrac60. It is a 2003 model with low hours (less than 2000 hours). When not used the tractor is parked in a barn that is not climate controlled. I do not use the tractor for my livelihood.
The rear tire are 14.9x28. I have noticed some tread wear but I am more concerned with the cracking I see on the sides of the tire.
I am looking for advice of how to know when I need to replace the tires. One one hand I think about waiting until I have a blow out on the other hand I know that if I have a tire failure it will be at the worst possible time in an area that is not easily accessible.
   / When is it time to repalce the tires #2
Tractor tires usually last decades unless they wear out first. I’d leave them. Chances are they’d start leaking before they suffered a catastrophic failure.
Thank you.
   / When is it time to repalce the tires #4
And when they start leaking, tube them and use them 10 more years.
   / When is it time to repalce the tires #5
That is what I do. I never could guess when a tire will fail. The belts provide strength. If they have enough tread and the tube can hold air use them. I would not run down the road at 15 mph with a bad tire, but in a field at 5 mph the tractor will fall in the dirt.
   / When is it time to repalce the tires #6
I had a Ford 1100 subcompact tractor that had tires on it so cracked it looked like a pond gone dry! I sold the tractor to a friend and he was all concerned about the rear tires, that he was considering backing out of the deal. I found some tires and rims in a junk yard and took them with me when I delivered the tractor, told him not to put them on till he had some sort of tire issue. He didn't listen, just put them on the next week. When I bought the tractor back, he gave me the original tires and rims, and they are still up, considering the fact that they are fluid filled. We are talking about a set of tires that came on the tractor in 1978!!
David from jax
   / When is it time to repalce the tires #7
Just yesterday the front tire sidewall on my Farmtrac 270 DTC blew as my wife was moving manure out to the manure pile. She said it made a hissing sound and she thought a hydraulic hose blew (goats like chewing on them). I told her she'd know right away if it was a catastrophic failure in hydraulic system. The unit is 15 years old with only 350 hours but has been stored outdoors throughout most of its life. Is it possible to insert a tube?
   / When is it time to repalce the tires #8
No
   / When is it time to repalce the tires #9
Get a barn and a new tire. the sun is extremely hard on tires......
   / When is it time to repalce the tires #10
No tube is going to fix that one, she gone!
2017 TAKEUCHI TB290 EXCAVATOR (A51246)
2017 TAKEUCHI...
Suzuki Kingquad ATV (A51694)
Suzuki Kingquad...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
