Wheels dont turn
/ Wheels dont turn #1
Rayreinke
283 massey ferguson
I have a 283 massey. Was shredding all going great. Stopped put tractor in neutral. Left pto running. Got on tractor to go again and it wont move. Good pressure on foot. Feels as if it went into gear. Any ideas
/ Wheels dont turn #2
"Good pressure on foot?" Meaning the clutch? First thought is a clutch issue.
/ Wheels dont turn
Sounds as if the gears are turning inside transmission. Pro does work
/ Wheels dont turn #4
I had a 283 years ago. I'm assuming it's the same tractor. You didn't happen to knock the range lever in neutral? That geared tractor should go. Have you tried all the gears in both ranges?
/ Wheels dont turn #7
Does the PTO go through the clutch? So if clutch is depressed it stops?
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2020 BROWN AND HUBERT 10' SPOOL TRAILER (A63276)
2020 BROWN AND...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
2018 Chevrolet Tahoe SUV (A64557)
2018 Chevrolet...
2013 Volvo BL70B 4x4 Extendahoe Loader Backhoe (A64553)
2013 Volvo BL70B...
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
