Tires wheel tube pin
/ wheel tube pin #1
rancher2009
Kabota B7200 HST-E D950-LA-H
Sunday 6/12/2011
I need help to find the Kubota part number for the "wheel tube pin" and what keeps it from falling out.
Left tire has come off due to pin falling out and got lost.
Can not find a dealer site that works with just the part name. All sites want a part number and manual does not list a number.
Thanks Rancher2009:cool:
/ wheel tube pin #2
Can you tell us the model of the tractor?
Are you referring to the front or rear axle housing on a B7200 tractor?
You can order a complete PDF download parts manual for your B7200
from several vendors if you desire to do so.
/ wheel tube pin #3
Assume you're referring to pin that allows you to adjust tread width...model?
/ wheel tube pin
Monday 06/13/2011
Yes it is a model B7200 HST-E D950-LA-H.
Yes it is the left rear wheel.
The Operators Manual does not list much for wheels.
Still have not found a parts list? Looks like the parts dealers want you to have the part number 1st before you get and thing.
I think it is a 3/8" x 4" inside long pin and something like a cotter to keep it from falling out.
Rancher2009:eek:
/ wheel tube pin #5
If it's any thing like the Kubota B7100 axle just find a proper sized bolt. Use a lock nut or double nuts for locking and then wrap some duct tape around it to hold things in in case of a break.[keeps the wheel in place]:):)
/ wheel tube pin
I Found then. FYI:)
Quantity Stock Qty Part Number Description Cost
1 Kubota 63733-17270 PIN, HUB $5.51
1 Kubota 62131-17290 PIN, SNAP $1.64
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
100 Gallon Galvanized Water Tank (A65579)
100 Gallon...
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
213097 (A64276)
213097 (A64276)
3 Point Boom Lift (A62613)
3 Point Boom Lift...
