Tires Wheel torque specs on a JD 3038e
/ Wheel torque specs on a JD 3038e #1
Rsware
Angleton,Texas
2013 John Deere 3038E
How many foot pounds of torque does it take to put on the rear wheels of a 2013 John deere 3038E tractor
Yeah I thought it did but I am having a hard time finding my manual
/ Wheel torque specs on a JD 3038e #4
Go by bolt size/ grade, should be very close.
/ Wheel torque specs on a JD 3038e #5
From the 3038e manual:
Front Wheel Bolts
Tighten front wheel bolts alternately to 140 N•m (103 lb-ft).
Rear Wheel Bolts
Tighten rear wheel bolts alternately to 140 N•m (103 lb-ft).
Thanks for the info
Thanks for the web site link
/ Wheel torque specs on a JD 3038e #9
Does anyone know how much torque is required for rear wheels on a John Deere 2130? The only information in the manual is for the front wheels and it says 240 ft-lbs. I wouldn't want to assume it's the same in the rear tires?
/ Wheel torque specs on a JD 3038e #10
Found it on google in 30 seconds. Didn't have to bother anyone.
/ Wheel torque specs on a JD 3038e #11
That was real helpful. You apparently don't want to be bothered by someones question yet you had enough time to look it up on the internet and then withheld the information to boot! It doesn't get any better than this!
Heck, why don't we just shut this forum down and let folks figure out everything for themselves? It would save all of us a lot of time and bother.
/ Wheel torque specs on a JD 3038e #12
But then he would have had to copy and past the link or actually type it. Who has that much spare time.
