Tires Wheel torque specs on a JD 3038e
   / Wheel torque specs on a JD 3038e #1
Rsware
Angleton,Texas
2013 John Deere 3038E
How many foot pounds of torque does it take to put on the rear wheels of a 2013 John deere 3038E tractor
Yeah I thought it did but I am having a hard time finding my manual
   / Wheel torque specs on a JD 3038e #4
Go by bolt size/ grade, should be very close.
   / Wheel torque specs on a JD 3038e #5
From the 3038e manual:
Front Wheel Bolts
Tighten front wheel bolts alternately to 140 N•m (103 lb-ft).
Rear Wheel Bolts
Tighten rear wheel bolts alternately to 140 N•m (103 lb-ft).
Thanks for the info
Thanks for the web site link
   / Wheel torque specs on a JD 3038e #9
Does anyone know how much torque is required for rear wheels on a John Deere 2130? The only information in the manual is for the front wheels and it says 240 ft-lbs. I wouldn't want to assume it's the same in the rear tires?
   / Wheel torque specs on a JD 3038e #10
Found it on google in 30 seconds. Didn't have to bother anyone.
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2013 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2019 Elgin V2403-CR-T Broom Badger Sweeper, S/N V2903-7JV8496, Kubota Turbo Diesel Engine, 4,664 (A59076)
2019 Elgin...
