Wheel spacing.
/ Wheel spacing. #1
JTS51
Hudson WI
Bobcat 5610D, ASV PT70, Case 850L, JD 5100M
I've got a 5100M with an MX8 cutter. I cut slopes & ditches. The rear wheel tread spacing is 59.6" CtoC. If I increase the spacing to 63.7", will I gain a lot of stability? Or doesn't it make much difference?
/ Wheel spacing. #2
I can't speak for your exact model tractor but can tell you when I widened the wheels by 4 inches on my 3720 cab tractor it made a world of difference for stability on the steep hills I mow. I'm really glad I added 2 inch spacers on each rear wheel. This was done after adding Rim Guard to the rear tires. The "pucker factor" is near zero now when working on the steep hills.
/ Wheel spacing. #3
Om my 3720 cab I went with RimGuard all around, reversed fronts, reversed rears PLUS a pair of 4" spacers and fender extenders. There are still a few places I cannot traverse, but its a helluva lot safer than the stock configuration.
If your 5800 is open station, you might get by with 2" per side. Depends on the lay of your land. Personally I'd go 4"/side, especially if a cab has raised your center of gravity
//greg//
/ Wheel spacing.
Thanks all for your advice. I'm going to move each side out 2" and see how that works for now.
/ Wheel spacing. #6
Just adding Turk Special Tires on my unit increased the stability quite a bit too. I am now considering adding 4 inch spacers to each side, to see if that will allow me to run a 72D Auto-Connect MMM on my unit with my Turf Specials. If not then I guess I will just switch to my R4s and then run with spacers to recapture the stability.
/ Wheel spacing. #7
I widened my 5083 wheels out as far as they would go when I got it. I like it much better than it was before. Putting some rear end weight would help mine for sure.
/ Wheel spacing. #8
Adding weight behind the rear axle - for anything other than front loader work - will actually decrease the amount of traction assist you get from the front drive.
//greg//
Auger Cart (A65640)
Auger Cart (A65640)
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
Tumblebug Hay Hauler (A64126)
Tumblebug Hay...
Ford 8N Tractor (A66408)
Ford 8N Tractor...
Ford 2 Row Corn Planter (A62613)
Ford 2 Row Corn...
2018 FORD F-350 (A65643)
2018 FORD F-350...
