wheel spacers
/ wheel spacers #1
fidler01
Jane Lew WV
john deere 2320
Can anyone recommend what width for spacers on a John Deere compact tractor 2320 (front and rear) all help would be grateful. Thanks
/ wheel spacers #2
Welcome to TBN.
Have you Google searched to see what's available?? I doubt you will find any that will work on the front. For example, if you use a MMM you'll hit your deck with the widen front tire stance when turning.
Are your rear wheels reversible? That might help. Fluid in the rears also helps.
What are you doing with the tractor that requires wider stance?
/ wheel spacers #5
I'm a little late seeing this, but OVRSZD is correct on the MotorSport Tech link. Contact Lenny Stahl there, he made a set for my LS XJ2025H that were perfect. They do fantastic work and get it to you quickly. All they need to know is the type/model tractor you have, and if it's not in their database they will need to know metric dimensions of the wheel and lug pattern. Good guys.
/ wheel spacers #6
I had installed 4" spacers on each rear wheel on the L3800 I previously owned. They worked well and really made a difference in terms of stability on slopes. I got the spacers from this source: Christian S. Hansen, Inventor, 510-601-7550 7135 Pinehaven Rd. Oakland, CA. 94611 www.TheTracksCompany.com. This was several years ago so I don't know if this information is current. Before you add spacers, be sure that your fender clearances will be okay. And as another poster suggested, see if you can set your wheels out wider and add ballast in the rear tires.
/ wheel spacers #7
I put 2 inch rear on my 3046r. Reversed the front tires and they seemed to be too far outside the rears so I went back stock on the front. A0FEE5E2-3A66-4CB0-8203-2994161A8411.jpeg939D4C58-4244-4D9B-AD87-87BAA0D81663.jpeg
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59914)
2004 INTERNATIONAL...
Loader Tractor Brush Grapple (A66408)
Loader Tractor...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
(7) Trailer Tires (A65640)
(7) Trailer Tires...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
