Wheel nuts/bolts
/ Wheel nuts/bolts #1
Kc8ehd
Hinton Wv
LS XR4040C
Tip:
Torque you wheel nuts/bolts at least yearly , damage to wheel lug holes from loose lugs isn't covered under warranty , and it's not a cheap fix . My XR4040C shop manual specs wheel nut/ bolts 16mm [5/8] torque to 131 - 145 foot pound . A torque wrench with 12 inch extension and 24mm socket is a lot cheaper than a wheel /stud/bolt replacement....
/ Wheel nuts/bolts #2
Even if the dealer had done it, you’re still supposed to retorque at every service interval.
I found that none of the lug bolts on mine were properly torqued as delivered. Some were close, some were way looser than required. I have calibrated SnapOn torque wrenches, so I know they are correct now.
/ Wheel nuts/bolts #3
The dealer? Who's checking loader bolts, tire pressures, etc?
Thanks Kc8ehd! (call sign?) Reminds me that I need a maintenance journal to keep up with service on more than one machine, and to be sure that's a top item if I don't. Some service shouldn't just be timed with fluid change, esp on 'backups' that don't see 50 hrs/year.
btw, I hire neighbor kids to check 40+ tire pressures weekly. Nothing wrong with putting psi and nut/bolt torque on rims with a paint pen.
/ Wheel nuts/bolts
That's a great idea , just marked mine , all wheels on the XR 4040 have the same torque. I do however run higher tire pressure in the front than rear [36 psig front 16 psig rear]
/ Wheel nuts/bolts
Affirmative on call sign [0003246733]
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A64556)
2019 Chevrolet...
2018 International LT Day Cab (A62613)
2018 International...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A65563)
2006 GMC W3500...
Adams Weight Hopper (A63689)
Adams Weight...
CHEVY 4X4 DUALLY TRUCK BED (A65643)
CHEVY 4X4 DUALLY...
