Wheel nuts/bolts
/ Wheel nuts/bolts #1
Kc8ehd
Hinton Wv
LS XR4040C
Tip:
Torque you wheel nuts/bolts at least yearly , damage to wheel lug holes from loose lugs isn't covered under warranty , and it's not a cheap fix . My XR4040C shop manual specs wheel nut/ bolts 16mm [5/8] torque to 131 - 145 foot pound . A torque wrench with 12 inch extension and 24mm socket is a lot cheaper than a wheel /stud/bolt replacement....
/ Wheel nuts/bolts #2
Even if the dealer had done it, you’re still supposed to retorque at every service interval.
I found that none of the lug bolts on mine were properly torqued as delivered. Some were close, some were way looser than required. I have calibrated SnapOn torque wrenches, so I know they are correct now.
/ Wheel nuts/bolts #3
The dealer? Who's checking loader bolts, tire pressures, etc?
Thanks Kc8ehd! (call sign?) Reminds me that I need a maintenance journal to keep up with service on more than one machine, and to be sure that's a top item if I don't. Some service shouldn't just be timed with fluid change, esp on 'backups' that don't see 50 hrs/year.
btw, I hire neighbor kids to check 40+ tire pressures weekly. Nothing wrong with putting psi and nut/bolt torque on rims with a paint pen.
/ Wheel nuts/bolts
That's a great idea , just marked mine , all wheels on the XR 4040 have the same torque. I do however run higher tire pressure in the front than rear [36 psig front 16 psig rear]
/ Wheel nuts/bolts
Affirmative on call sign [0003246733]
(10) New CATERPILLAR Keys (A65579)
(10) New...
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
2020 JOHN DEERE 333G SKID STEER (A65053)
2020 JOHN DEERE...
(2) Planter Boxes (A66408)
(2) Planter Boxes...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
