Wheel base
/ Wheel base #1
eppoh
Texas
Iseki TS1610
On my 1610, the rear wheels can apparently be remounted to the rims to widen the rear wheel base by about 6 inches. I noticed sometims the rear lift arms rub the tire lugs when pulling the mower around corners. Is there any down side to widening the rear wheel base, more than the front?
/ Wheel base #2
No down side, unless your plowing a field and want the front and back to track in the same furrow. It will give you more stability on hills to have the back wheels wider. I have my back wheels wide.
You can remount the front also but they don’t go out as wide as the back. I don't see a reason to widen the front. Unless you want them closer to the same track.
Used Landpride GR1525 Stump Grinder
Used Landpride...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
24in excavator tooth bucket (A61307)
24in excavator...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - Tier 2 - Irrigation Takeout (A63689)
Kubota V3600-T-E2...
