What's wrong with my seat?
/ What's wrong with my seat? #1
npaden
Platinum Member
Lubbock, Texas
2011 LS U5030C
What\'s wrong with my seat?
Okay, I'm pretty slow I guess.
I can't figure out what's wrong with my seat. It is unstable and tippy and I don't feel comfortable on it. I got the tractor used and I'm working through several hopefully minor issues to get everything sorted out.
Here are some pictures:
I circled the pieces in red that seem like they should be attached to something and are broken or something. They are attached at the bottom and swivel back and forth but I can't figure out what to attach them to.
I can't figure it out from the parts diagram:
Thanks, Nathan
/ What's wrong with my seat? #2
Re: What\'s wrong with my seat?
Nathen,
Went out to look at mine and it is a little different. I looks like the pieces you circled should be attached to the mounting plate that is now pivoting forward. See attached.
Hope this helps,
Gary
Thanks. That's what I was leaning toward but wasn't sure.
It is going to be fun getting them attached. I may have to take it apart to get it back together they don't look like they will slide in very easy.
The odd thing is that they aren't in the parts diagram at all.
Thanks, Nathan
/ What's wrong with my seat? #4
That looks very much like a parallel linkage setup. I second the idea of the green lines in the retouched photo. The extensions beyond the pivot points with the bevelled edge look like "stops" to keep tension in the springs.
/ What's wrong with my seat? #5
Nathan
That part is attached and you also need to have the top piece to capture around the adjuster (see attached pic)… KennyV.
/ What's wrong with my seat? #6
I guess they are not in the part diaqgram because that is all one piece, no replaceable parts. That reminds me, the rubber bumpers on mine need replacing..
Well, I got it all put back together correctly. Thanks for the help.
Turns out the seat isn't a Kubota seat anyway.
At least it is all connected and not as tippy as before. Not sure I'm happy with it overall. I think I'll be keeping my eye out for a new seat.
Thanks, Nathan
/ What's wrong with my seat? #8
<font color="blue"> Turns out the seat isn't a Kubota seat anyway. </font>
Nathen,
I was wondering why it looked so different?
But good to hear you got it working. I would try to get it back to stock if for no other reason than to make sure your seat belt is working correctly. Some times you only get one chance!
Gary
2004 Mack RD690S Tri-Axle Rolloff Truck (A64194)
2004 Mack RD690S...
2021 BOBCAT T62 R-SERIES SKID STEER (A65053)
2021 BOBCAT T62...
2013 Ford Taurus AWD Sedan (A64194)
2013 Ford Taurus...
2022 MERCEDES SPRINTER 2500 S/A CARGO VAN (A67147)
2022 MERCEDES...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
2009 Caterpillar 345D Hydraulic Excavator (A64553)
2009 Caterpillar...
