Rotary Cutter What's under that rotary cutter?
   / What's under that rotary cutter? #21
Re: What\'s under that rotary cutter?
On my Woods 6' rotary cutter there is a small access cover that permits you to loosen the blades from above. Be prepared! I just bought a 1 3/4" socket and 19" breaker bar. To that I added about 3' of 1" pipe for leverage. My manual specs the blade bolt torque to 450 ft lb!
On a related note, my efforts to sharpen the blades (with a belt sander) seem to be working pretty well.
Peter
   / What's under that rotary cutter? #22
you can also use a 4" grinder to shapen your blades
   / What's under that rotary cutter? #23
<font color=blue>...How do you change a blade?...</font color=blue>
Well, see that access hole in the rotary deck... if you have real small tiny fingers and hands and you're real strong.... /w3tcompact/icons/tongue.gif/w3tcompact/icons/wink.gif
or insert a 1 11/16 socket through that access hole - attached to a long lever with a little muscle... /w3tcompact/icons/smile.gif
Thanks again John. Your pictures are worth a thousand words.
DEUTZ MARATHON...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
KOMATSU D65EX-18 CRAWLER DOZER (A60429)
KOMATSU D65EX-18...
