what's this?
/ what's this? #1
Anonymous Poster
Epic Contributor
what\'s this?
I borrowed (okay, stole) this picture off the forum from Cchoate (thanks!). It's a dirt scoop. It looks as if it could be used in place of a FEL. I know, a FEL would be a lot more versatile. But if I'm on a budget and I'd be a lot better off paying $12,000 instead of $15,000, AND I don't have a lot of digging to do, wouldn't this be a pretty good substitute for a FEL? Just curious.
/ what's this?
Re: what\'s this?
Second question -- can it be mounted on the front?
/ what's this?
sorry, here\'s the picture
I guess my CRS is acting up again. Here's the picture.
/ what's this? #4
Re: what\'s this?
You can get a brand new tractor/loader for under $10K
/ what's this? #5
Re: what\'s this?
I soft soil etc..you should be fine,but the hard stuff..rocks etc..I would be gentle,for you don't want to damage the 3 pth etc..backing up to fast while loading.
You may also want to consider some front weights.
/ what's this? #6
Re: what\'s this?
I have a scoop like that, and it has been very useful. I used one to dig a 300' long swale along one side of our property. They can be mounted to FACE front or rear, but not ON the front or rear. It would be easier to get a FEL than adapt the scoop to the front.
The scoop has limitations. It has very limited lift, gravity dump, no down pressure, doesn't "curl" and is difficult to excavate (evenly) a width greater than the scoop width.
All I had to work with for a long time was a scoop on my Ford, and I moved a lot of dirt. It was far far better than a shovel and wheelbarrow. I got the 'Bota w/FEL last year, and have been surprised at how much easier it is to do small projects around the property. Spreading stone, light digging, gathering up big storm-damaged limbs, transporting heavy things, picking heavy loads off (and onto) the pickup, piling snow, etc have made the FEL one of my most appreciated attachments...................chim
/ what's this? #7
Re: what\'s this?
That dirt scoop has been great for the jobs it's been used for. In 4 months I have:
- edged around my pond
- dug a big overflow for my pond (30'x20'x4'deep)
- moved and spread 3 big hills of road fill
- leveled off some rough ground
- carried rocks, bricks, ect...
Yes, a fel does more, but the dirt scoop was $260 at TSC and the fel is $2800. Check out the picture of just dug pond "muck".
/ what's this? #8
Re: what\'s this?
I had a scoop before I got my loader. For $300, you can do a lot of stuff. For 1/10 the cost of a loader, it'll work just fine while you save up for the $3000+ loader.
There was a guy on this forum a few years back that built his own rear loader. It was effectively a wider scoop. He added a "tip" cylinder/valve and could then "curl" the scoop. His scoop was pretty much the same size as a loader bucket for his sized tractor. He made it all at home for cheap. In fact, before I got my loader, I emailed with him; he made a couple more for his buddies.
/ what's this?
Re: what\'s this?
We sell a lot of these new material scoops (in various widths) to customers that cant justify the FEL dollars. They are not as handy as a FEL-- however a New $260 material scoop seems to be a resonable alternative for your situation! --Ken Sweet
/ what's this? #10
Re: what\'s this?
NOPE! can't be used in place of a fel, can u dig with it? can u lift and move dirt with it? can u back drag with it? the scoop is a nice implement, but won't take the place of a fel.
/ what's this? #11
Re: what\'s this?
<font color=blue> NOPE! can't be used in place of a fel, can u dig with it? can u lift and move dirt with it? can u back drag with it? the scoop is a nice implement, but won't take the place of a fel. </font color=blue>
Whooee Frank. Good thing I didn't read your post before I went out and dug, moved dirt and back dragged with the scoop on my L210. Or were you kidding?
I won't be putting a FEL on the old girl....would cost more than she's worth. So, until I get a newer tractor I'll have to make do with the scoop for such work.
It was also handy as a carrier for the wood I salvaged from some power line work that was inflicted on my place.
My only complaint with the one I bought, a KingKutter, is that the dump mechanism is pretty stiff and you can't always dump without first setting the bucket down to take the pressure off. That turns out to be no big deal, but I will have to come up with a better place to hang the end of the rope that I pull on. I have the handle just hanging from a bolt on the fender, and with the bucket up the piece of wood dowel I use as a grip can bang on the tire. So, move the bolt dummy!
Chuck
/ what's this? #12
Re: what\'s this?
The main drawback is the lift/dump height.... You won't be dumping into truck beds unless you have a ramp..stable ramp.. etc.
For incidental dirt movement it is great. I had a few dump truck loads of dirt left over from my house construction, and let them dump it inmy side pasture. Any time I get a hole to be filled or need dirt I can go scoop it up etc.. works reasonably well. I move about 10 yards of it with my 1979 yanmar 1700 and some front weights.
A front end loader it is not. As a powered self loading wheelbarrow it is absolutely stupendous !
So far on my farm it has done what I needed it too... Not as handy.. but way less $pendy...
Soundguy
/ what's this? #13
Re: what\'s this?
Hey, that looks like... a big ol' load of back breaking dirt. If you don't have the money for a loader, that seems like a cost effective alternative to a wheel barrow, for sure. Anything to save your back, right?
/ what's this? #14
Re: what\'s this?
You got it Moss Road.
I'll be adding one of those as soon as I get my Midwest Quick Hitch.
Jerry
2025 Safety Basket Forklift Attachment (A61572)
2025 Safety Basket...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
LOOK! (A63116)
LOOK! (A63116)
2014 John Deere 644K High Lift Articulated Wheel Loader (A61572)
2014 John Deere...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
GAMOR MACHINE CO. 4R VEGATABLE SEED PLANTER, 3PT (A64280)
GAMOR MACHINE CO...
