What's the point...
Status
Not open for further replies.
/ What's the point... #111
Neither. They both go flat quickly once opened and stored in the cup holder. Best to finish them quickly.
Yep sounds like an operator problem if it is going flat :licking:
/ What's the point... #112
Little did Arc Weld realize how spot was his naming of this thread!
/ What's the point... #113
Brian you make 3 good points here, thank you. You are right the bigger topic is how things are discussed on the internet, not actual "welding". Every once in awhile there is a response from a pro that is the real deal.
3) A bully's goal is to elevate himself, he will gravitate towards challenges that he expects to win. But on the other hand, I bet you didn't post any pictures of welds that were serviceable,,,,,, (but you know that in the right conditions, position, access, with more time to prep, higher $bid, etc) you could have done much "better". So what? The job is done and once you have enough experience you know its good.
Sodo
As far as I am concerned you stand on pretty shaky ground condemning anyone else for bullying on the internet.
I bought a 120v machine and before I used it I asked you for advice because I thought you did some pretty good work with a 120v machine. I admitted I had no welding experience. You yourself told me that what I wanted to do was at the limit of the machine so I took it back and got a 120/220v machine -- primarily on your advice (if the 120v welder says it is at the limit it must be so). Next thing I know you jumping up and down (metaphorically) and very sarcastically calling me a !!!! liar. Made me just step out of the conversation.
Seems pretty hypocritical faulting somebody else's internet etiquette.
Status
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
Kubota B2301 (A60462)
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
Land Survey Kit (A60463)
Land Survey Kit...
2012 DRAGON 130BBL VAC TRAILER (A60736)
2012 DRAGON 130BBL...
