What's a reasonable weight to lift?
   / What's a reasonable weight to lift? #1
Chris_in_Oz
South of Perth, Western Australia
Iseki TU155 Landhope
What\'s a reasonable weight to lift?
I have built a crane attachment that connects to the 3pt hitch. It lifts to about 3m, via hydraulics, and has a cable, hand-cranked, winch mounted on it.
I understand the force x distance laws and all that, I also understand about front end weights for counterbalance.
What I would like to know is: What sort of output can I expect from a standard Iseki hydraulic pump? From this I can extract the pushing force of the piston and use this to work out how much my rig can lift.
Cheers, guys! /forums/images/graemlins/wink.gif
   / What's a reasonable weight to lift? #2
Re: What\'s a reasonable weight to lift?
Lift capacity at the 3 point on that model is 800 lbs.
Buck
   / What's a reasonable weight to lift? #3
A rough estimate is about 2000psi on the pressure relief setting. Remember, pumps make volume, restrictions (like a valve working a cylinder) make pressure, relief valves regulate max pressure.
Buck, is that close on the relief pressure? I've not put a gauge on one of these.
   / What's a reasonable weight to lift? #4
That or even less if it is a little worn
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
1266 (A50490)
1266 (A50490)
2002 CLEMENT END DUMP TRAILER (A52472)
2002 CLEMENT END...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
2020 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2020 PETERBILT 567...
