What's a reasonable weight to lift?
   / What's a reasonable weight to lift? #1
Chris_in_Oz
South of Perth, Western Australia
Iseki TU155 Landhope
What\'s a reasonable weight to lift?
I have built a crane attachment that connects to the 3pt hitch. It lifts to about 3m, via hydraulics, and has a cable, hand-cranked, winch mounted on it.
I understand the force x distance laws and all that, I also understand about front end weights for counterbalance.
What I would like to know is: What sort of output can I expect from a standard Iseki hydraulic pump? From this I can extract the pushing force of the piston and use this to work out how much my rig can lift.
Cheers, guys! /forums/images/graemlins/wink.gif
   / What's a reasonable weight to lift? #2
Re: What\'s a reasonable weight to lift?
Lift capacity at the 3 point on that model is 800 lbs.
Buck
   / What's a reasonable weight to lift? #3
A rough estimate is about 2000psi on the pressure relief setting. Remember, pumps make volume, restrictions (like a valve working a cylinder) make pressure, relief valves regulate max pressure.
Buck, is that close on the relief pressure? I've not put a gauge on one of these.
   / What's a reasonable weight to lift? #4
That or even less if it is a little worn
2014 GALYEAN 180 BBL STEEL VACUUM TANK TRAILER (A52472)
2014 GALYEAN 180...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52748)
DeeZee Crossover...
