Whatever you feel like thread.
/ Whatever you feel like thread. #511
lol... if that was directed at me, then you're under some wrong assumptions about my home! The "newer" doors and windows in the room in which I am sitting now were installed in 1775. The older ones in the room directly below me were installed around 1734. I can see the morning sunlight pouring onto the floor from outside thru the big gap under the door next to me now, and we get SNOW coming in around the edges of the door below me. We have 13 exterior doors and 60 windows, most of which were built and installed in 1775. This house is so "not airtight" that I'd doubt there's a blower door motor powerful enough to actually run a leak test on this big old house. :ROFLMAO:
As to why others aim for air tight? I don't think they do, anymore. HRV's are the name of the game now. People learned their lessons with mold and other problems in the 1970's and 80's, I don't think anyone is going for air tight today, but rather controlled air flow with heat recovery.
No not at you but over 20 yrs ago all home builders seemed to talk about was trying to make homes practically air tight. I think there's a combination that can be reached by letting a home breath without cold or hot drafts blowing thru it.
/ Whatever you feel like thread. #512
I think that for the last 20-30 years, the goal has been to eliminate any unintentional leaks, and direct all ventillation thru heat recovery ventillation (HRV) systems. I suspect the recommended size and number of HRV's probably has increased some over time, but since my house is so leaky that adding an HRV would be like pissing in the ocean, I've never really researched them myself.
/ Whatever you feel like thread. #513
Worse than that: many progressive politicians decided to write airtightness into local building codes. Around here one can build using certain practices such as taping all seams of the outer sheath, gluing the tops and bottoms, around windows, document with pictures. Or, hire a certified test contractor with a fan and manometer.
/ Whatever you feel like thread. #514
We keep a cast iron "tea pot" on the wood stove. Add another pot when needed on the really cold days (by our standards)
We used to do the same. But because we had hard water, lime would build up in the teapot. My mother would keep marbles in the teapot that would dance around when boiling the water to break up the scale.
/ Whatever you feel like thread. #515
We just add some vinegar now then to dissolve the lime. Have to treat the coffee maker every few weeks as well.
/ Whatever you feel like thread. #516
Why does looking up help you sneeze?
/ Whatever you feel like thread. #519
When feel like a sneeze but you're not sneezing...just look up (particularly towards the sun) you will sneeze.
I remember reading about this once, a few years back. It's a sign that your nerves are a bit cross-wired, if you sneeze when looking at a bright light, and thankfully not everyone suffers from this problem!
Just did a quick search, and found this explanation of it:
/ Whatever you feel like thread. #520
Whenever I look at the sun I have photopsia paroxysmal flatulent dyspepsia reflex response.
Everyone is so amazed I can sneeze, cough, fart and belch simultaneously but even more amazed I can pronounce it.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2020 Case 5550 Trident (A61307)
2020 Case 5550...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
2017 Chevrolet Tahoe SUV (A59231)
2017 Chevrolet...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
