Whatever you feel like thread.
/ Whatever you feel like thread.
Our church yard has a couple of large trees and gets lots more leaves than our yard does. Suppose I should get mulch blades for it, but its not been a issue here.
/ Whatever you feel like thread. #342
I’ve had a mulch setup on about every mower I’ve had. You about have to get a discharge chute block off and baffles for it to work correctly.
/ Whatever you feel like thread. #344
My opinion on mulch setups is that don’t work well if the grass is wet. They actually cut fine it just gunks up the deck. They also don’t work well if the grass is really long. I don’t think anything works well if the grass is long since a regular deck will leave a windrow of cut grass from the discharge.
/ Whatever you feel like thread. #346
Looks like Ego offers a mulch kit for this machine which appears to be just a plug and mulching blades. Anything to hold the leaves in the chamber longer will help with the mulching.
Ya, I just seen that as well. Might get it.
/ Whatever you feel like thread. #348
I tried mulching blades on my zero turn a few years ago. I hated them. They created a massive dust cloud whenever I mowed across an area with exposed dirt. I also didn't care for the grass looked with them.
/ Whatever you feel like thread. #349
Use Gator blades on my Cub Cadet ZTR. Block off the deck discharge with a piece of 5/4x6 deck plank. Drilles holes in each end and use tarp strap to secure it to the pully covers. I pass through leaves to chop them up coarse and then final pass to make itty-bitty pieces. Works good for me.
/ Whatever you feel like thread. #350
Knocked down our 4 acres today. Maybe for the last time? Took a little under three hours. Some isn't what I'd consider "manicured", so it's pretty rough.
I went with a gasser because I wanted a 72" deck
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
207283 (A52708)
207283 (A52708)
Giyi DHC Mini Quick Attach Forks (A60463)
Giyi DHC Mini...
