ArlyA
Super Star Member
- Joined
- Mar 18, 2016
- Messages
- 14,414
- Tractor
- Outlander1000 6x6, Ego lawn mower and shopping for tractor
With rain here, I've been mowing every 3 or 4 days. Been more happy with the machine with use.
Grass was light, while slope was heavy.Too much slope? or too much grass?
On the way up, the front was getting real light. On the way down it would tend to slide. Side hills worst! There yard is quite steep so I was there just to see if it was functional.What was happening with the slope? Sliding? not enough power to mow going up the slope? Could you mow going downhill or sideways?
Good post. And to take it a step farther, how that distribution affects soil contact pressure. A light machine is just fine, if the tire size is adjusted for similar contact patch pressure.It's not the weight of the machine. It's the weight distribution
No. The neighbors were out of town and let there yard go so I was only there to see if it could do it. It was really steep.On the other hand..... he said this was just an experiment to see what the capabilities of the machine are. Well, he now knows what the limitations are, and as he said previously, it works fine on his own yard, which I understood to be the only place he's really going to use it.
So, trying to add weight, etc., is just trying to solve a problem that doesn't really exist. It might also put extra strain on the drive train and cause it to have less range.
That slope looks to be at least 20 degrees which would be quite a bit for any mower.
Arly, are you planning on mowing this yard (or this kind of slope) any more, or just a one time thing?
I have a Toro MyRide ZMaster 2000. It has the full suspension. Unfortunately my property is not very smooth and mowing bahia grass I can't go full speed. More like 1/4 speed.I cut at full speed here all the time. A ZTR with full suspension will allow that. When cutting all the mower is doing is just soaking up the bumps and transmits very little to the operator. Full suspension and the weight of a big mower does that. Ever ride a good suspension side by side ? The big ones have giant shocks to absorb the bumps at speed. That allows you to travel faster on a bumpy trail than anyone else. Hence the reason for full suspension on a ZTR. And in control I'll add too. Not just flying along out of control.
