What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ?
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #51
That whole guard comes off by removing 5 easily gotten too bolts then it’s out in the open (y)
That's a nice looking machine! The fuel filter location is where I added my Racor 2u filter / separator last year. I also removed the (2) individual tank filters and installed a pre-filter on the common line after the tanks.
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #52
Yea, a lot to like about those filters. The ones on my 1211 are cheesy at best. I put my zero turns on my car lift to do any work on them. Sure makes life easier.
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #53
Same here.
I have a 2 post lift makes life a lot easier.
90cummins
… The fuel filter location is where I added my Racor 2u filter / separator last year. I also removed the (2) individual tank filters and installed a pre-filter on the common line after the tanks.
Did you remove the OE check valves at each filter ?
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #55
I left the check valves before the "T".
Result:
Tank > Check Valve > T > OEM Filter > OEM 12v Pump > Racor Filter > Secondary added 12v Pump > OEM Filter > Injector pump.
I really like your new mower! Sorry the F didn't work out, but better to move on and cut your losses.
Thanks RjC 👍
Yea I couldn’t see keeping the expensive front deck as a backup mower since it wouldn’t stay on my bank sideways.
Big Heavy Commercial Zero fits my application way better.
I ran my ZD1511 6hrs ystrda & a 5hr ride today in super thick tall grass & I’m still not done 😬 : from so much rain the last 2wks that I couldn’t mow any.
Lots of grass here on the chicken farm
These V1505 4cyl Turbo motors are truly amazing although I could use more power like the F3710.
The 3cyl ZD1211 I sold few years back just wouldn’t muscle thru thick grass or hills.
New Holland 273 Hayliner Square Baler (A50515)
New Holland 273...
2012 Ford F-450 Altec Bucket Truck (A50323)
2012 Ford F-450...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51243)
2006 FORD F-450...
2019 BOBCAT E35I EXCAVATOR (A51242)
2019 BOBCAT E35I...
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
