What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ?
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #51
That whole guard comes off by removing 5 easily gotten too bolts then it’s out in the open (y)
That's a nice looking machine! The fuel filter location is where I added my Racor 2u filter / separator last year. I also removed the (2) individual tank filters and installed a pre-filter on the common line after the tanks.
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #52
Yea, a lot to like about those filters. The ones on my 1211 are cheesy at best. I put my zero turns on my car lift to do any work on them. Sure makes life easier.
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #53
Same here.
I have a 2 post lift makes life a lot easier.
90cummins
… The fuel filter location is where I added my Racor 2u filter / separator last year. I also removed the (2) individual tank filters and installed a pre-filter on the common line after the tanks.
Did you remove the OE check valves at each filter ?
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #55
I left the check valves before the "T".
Result:
Tank > Check Valve > T > OEM Filter > OEM 12v Pump > Racor Filter > Secondary added 12v Pump > OEM Filter > Injector pump.
I really like your new mower! Sorry the F didn't work out, but better to move on and cut your losses.
Thanks RjC 👍
Yea I couldn’t see keeping the expensive front deck as a backup mower since it wouldn’t stay on my bank sideways.
Big Heavy Commercial Zero fits my application way better.
I ran my ZD1511 6hrs ystrda & a 5hr ride today in super thick tall grass & I’m still not done 😬 : from so much rain the last 2wks that I couldn’t mow any.
Lots of grass here on the chicken farm
These V1505 4cyl Turbo motors are truly amazing although I could use more power like the F3710.
The 3cyl ZD1211 I sold few years back just wouldn’t muscle thru thick grass or hills.
2006 International 4400 LP Ambulance (A50323)
2006 International...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2005 INTERNATIONAL 4300 CARGO TRUCK (INOPERABLE) (A50854)
2005 INTERNATIONAL...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
