What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ?
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #51
That whole guard comes off by removing 5 easily gotten too bolts then it’s out in the open (y)
That's a nice looking machine! The fuel filter location is where I added my Racor 2u filter / separator last year. I also removed the (2) individual tank filters and installed a pre-filter on the common line after the tanks.
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #52
Yea, a lot to like about those filters. The ones on my 1211 are cheesy at best. I put my zero turns on my car lift to do any work on them. Sure makes life easier.
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #53
Same here.
I have a 2 post lift makes life a lot easier.
90cummins
… The fuel filter location is where I added my Racor 2u filter / separator last year. I also removed the (2) individual tank filters and installed a pre-filter on the common line after the tanks.
Did you remove the OE check valves at each filter ?
   / What ZD is replacing the discontinued ZD1511 Zero Diesel Turbo Mower ? #55
I left the check valves before the "T".
Result:
Tank > Check Valve > T > OEM Filter > OEM 12v Pump > Racor Filter > Secondary added 12v Pump > OEM Filter > Injector pump.
I really like your new mower! Sorry the F didn't work out, but better to move on and cut your losses.
Thanks RjC 👍
Yea I couldn’t see keeping the expensive front deck as a backup mower since it wouldn’t stay on my bank sideways.
Big Heavy Commercial Zero fits my application way better.
I ran my ZD1511 6hrs ystrda & a 5hr ride today in super thick tall grass & I’m still not done 😬 : from so much rain the last 2wks that I couldn’t mow any.
Lots of grass here on the chicken farm
These V1505 4cyl Turbo motors are truly amazing although I could use more power like the F3710.
The 3cyl ZD1211 I sold few years back just wouldn’t muscle thru thick grass or hills.
CAT RM-300 (A50854)
CAT RM-300 (A50854)
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
2017 CHEVROLET 2500 HD (A50854)
2017 CHEVROLET...
