Buying Advice What you should have ordered from PT
   / What you should have ordered from PT #31
I have been mulling hose jumpers, meaning two couplers that have male / female on each end so I can change the direction. I see the ideas of adding a circuit switch but the cost seems to me to be so high... Gonna have to research it.
   / What you should have ordered from PT #32
Looks like a manual double selector valve is $97, that might suffice if there is someplace you can reach to put it (or as a "whoops fixer"): 3/4" NPT 30 GPM PRINCE DOUBLE SELECTOR VALVE or 1/2" NPT 20 GPM DOUBLE SELECTOR VALVE
Aaron Z
   / What you should have ordered from PT #33
My 12V controlled selector valves were only $140. For the extra $43, I would much rather have the luxury of pressing a button on the joy stick.
Ken
   / What you should have ordered from PT #34
Re: What mods you should have ordered from PT
OK; here's the list of factory mods I will inquire about:
  • replace casters of brush hog with ones from landscape rake (higher)
  • Female QDs for Aux. and PTO hydraulic couplings
  • 4in long hose with female QDs for each powered implement (to 'close the loop')
  • hydraulics with Rotella T6 5W30 (synthetic)
  • tie-down hooks on four corners (for securing on trailer)
  • longer wheel studs and 1/2-3/4" spacer to allow for tire chains
  • reversible motor on tiller
  • 6-ply tire like on model 1445
We'll see what they say...
Remember, if you raise the brush hog too high up off the ground, debris will fly out farther, including into the hoses and tunnel opening on the front of the PT under the FEL arms. You'll regret that decision later when you pummel the hoses with rocks and wood chips. ;) Solid tires on the brush hog are a must! :cool:
The Main PTO comes with one female and one male connector and so do all the implements. This prevents incorrect hook up for rotating equipment. You can hook the implement hoses together when not in use. This protects them from dirt and also allows you to spin the implement motor with your hands if you need to. So you shouldn't need to do anything to the Main PTO or any of the implements that run off of the main PTO.
The AUX PTO comes with male ends on both connectors on the FEL arms. And any implement that uses the AUX PTO (like the power-angle on the snow plow) comes with two female connectors. I don't know why they do this. However, in my opinion, its not worth messing with. The only problem it causes is if you hook the hoses up differently, the plow will angle left with a lever pull one time, and right the next time if you swapped the hoses. A simpler, and more cost effective remedy to prevent this would be to simple paint a color stripe on one of the AUX PTO connectors on the FEL arms and on the corresponding female implement connector of your choice. That way you always hook it up the same way each time. Doesn't cost anything but a small can of paint and a brush and tape if you like neat stripes! :thumbsup:
I think 30W oil is too low for the hydraulics. Mine has 40W in it from the factory.
Tie down hooks are a good idea. I use the trailer hitch on the back of the PT for the rear, however, its a single point. Two would be better. There's no good tie down point from the factory on the front. I added a hook to mine, but factory hooks located higher than the front tires on the front of the unit would be nice. Hmmm..... I may have to do that to mine, myself! :laughing:
Don't know about wheel studs and chains and such.
If you get a reversible motor on the tiller, you'll need a way to reverse it. Two short hoses with male/female quick connects would take care of that pretty cheaply if made at a local hydraulic shop VS having PT make them. You could put in a reversing circuit on the main PTO as well, but then you have the operator responsibility of making sure that you have it in the proper direction when brush hogging. It ads a level of failure to the human, if you know what I mean. ;) I'd try to un-jam it by just dragging is with some down pressure on the tines first. If that didn't work, pop in the short reversing hoses and run it backwards.
   / What you should have ordered from PT #35
Also, just thought that you wouldn't need to have a hydraulic shop make the gender-benders if you just use solid fittings. It would be inflexible, of course, but you could do it yourself with a couple wrenches and pipe dope.
   / What you should have ordered from PT #36
I'm seconding MR's comments on painting or labeling the AUX connections.
I use blue and red cable ties on my AUX cables to keep things operating the same way. In five years, I have had to replace one cable tie.
When I was purchasing my PT, I wanted a reversing tiller, but I have found that in practice that I don't need it. When it jams, e.g. on a rock, I idle the PTO, leave the tiller on the ground and back up. The ground motion causes the debris to fall out, and I can keep going.
YMMV.
All the best,
Peter
Thanks again for the feedback! :)
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
2016 CATERPILLAR M322F MOBILE EXCAVATOR (A60429)
2016 CATERPILLAR...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
ALLISON TRANSMISSION (A55745)
ALLISON...
2018 Dodge Journey SUV (A59231)
2018 Dodge Journey...
