Just ordered a PT-180, wanted to introduce myself
   / Just ordered a PT-180, wanted to introduce myself
So finally got a chance to mow the entire lawn this weekend and really get a feel for it.
1. My serial number is like 20817 or 20819 (cant remember). But I am certain it was lower than 20822. So who knows what that means. The grippy tape on the foot pedal was just barely worn on the right side, perhaps this was a demo? I looked it over real good, if it was a demo I can't really tell.
2. Tightened that big center pivot nut with my pipe wrench. I wouldn't call it loose, but definitely turned a bit easier than I expected.
3. Using both feet on the pedals and it's much much better. Springs aren't necessary at this point.
4. Got the hour meter and magnetic temp sensor put on. Got an electrical fan, headlights and oil pressure warning light waiting in the garage. Going to just add a fuse block and some power upgrades for future expansion, so that will take some time. My dashboard is from a 422/425 with a plate over the Hour meter , lights and pto holes. I took that plate off and my hour meter fit right in the hole, and I need to bore slighly bigger holes for my fan and light switches.
I knew going into mowing that the PTO generates a lot of heat. I was watching my magnetic temp gauge and it hit 175 within ~45 mins of mowing. I feel like what I have read on here that 180 is really the max. So I just took a break and finished the rest the next morning. The steering is interesting, some parts of my yard require a lot of maneuvering. I tore up the grass in a few spots, but I think that was operator error. I also now see how you can get this thing wedged against a wall/fence/tree etc. as I came close to doing that a few times :). I'm curious how much a fan without a radiator will affect hydraulic temps. I'm also debating on the best placement of the fan. Current thought is on the right side, blowing air into the compartment and over the exhaust. Will be a bit of an experiment.
Ordered the wrong covers for my PTO quick connect, for some reason I thought it was 3/4 inch valves, but now I'm guessing its just 1/2. Going to measure next time I am there to be sure. Also bought some super-lube and a grease gun, as I am quickly approaching 8 hours. Overall I'm super happy. I keep asking my neighbors if they need anything moved around just come find me :).
For $6,500 I would completely agree it was a steal of a price. You could buy two of these tractors for the price of 1 425. The price almost didn't make sense. I usually drag my feet with stuff like this, I was sooo happy when I saw the price increase...happy that I had already ordered. I really wonder if they just left the price low to move old inventory. At the new price of $8,000 I think I am just buying a 422. After all is said and done I'm probably spending close to $1,000 in parts and labor to add all of this stuff, so to have it "factory" seems smart.
   / Just ordered a PT-180, wanted to introduce myself #32
Just my opinion here so take it with a gain of lawn salt.
I think Power Trac has a number of tractors ready to sell and they take the one that fits what you ordered. I wanted agricultural tires and got that S/N, you may have ordered turf, so PT takes the one appropriate, which may have had the older S/N. That tape looks nice, but it is long gone on the edges which is the only place I contact mine.
After writing that it makes me think if it would feel better if the pedals were angled like the pedals on a car, why should it face up?
Anyway one thing you may want to do is remove that treadle pedal and bend the left side almost flat (do in stages so you don't go too far). The tractor goes way to fast in reverse, so I attempted to limit the speed. The wife's foot slipped of the forward pedal and she took off in reverse:shocked:, now doesn't like the tractor anymore:sarcastic::sarcastic::sarcastic::sarcastic:.
On the center pin, I bought the correct size wrench off ebay for cheap money. I cringe hearing a pipe wrench and think what the nut will look like after a few tightenings, then a wrench wont fit.
On the low oil alarm, will you be able to see the light in sunshine? Where I use mine, the most likely time it will come on is when I am on severe terrain (sideways, up or down), at which point I have to hang on for dear life and won't be looking for lights.
Your right about the new price being too close to the 422 which will be the better buy if you are going to modify. But even with the 422, who wants to have incandescent lights, no oil alarm and no hyd temp indicator?
I figured I should mention this because it was easy (although very mickey mouse). When I got mine and was monitoring the hyd temp and couldn't control it, and want to use the tractor more. I racked my brain on how to get it down without a lot of work. So I cut a gallon milk jug in half, squeezed the lower part under, but surrounding the hyd filter, I then filled it with water so the hyd filter was part under water. This actually made a difference as long as you can keep the water level up and change it out with cold again. Then when you change the filter at 50 hours, it collects the mess too.
   / Just ordered a PT-180, wanted to introduce myself #33
I frequently run my PT425 at full speed (8mph) in reverse. It is extremely handy when moving heavy bucketfulls of material. If you move them forward, and the unit bounces and the bucket digs in it can jar the heck out of you, while if you are moving full speed in reverse and the unit bounces, the bucket just skips on the ground like a wheelie bar and you keep on going nice and smooth.
I also pull logs at full speed in reverse with the tongs on the FEL arms.
It may come in handy for you some time, so don't bend the pedals to make it unable to attain that speed. Instead, consider some type of mechanical limiter, adjustable/removable stop sort of thing if the full speed reverse scares you.
   / Just ordered a PT-180, wanted to introduce myself #34
I use my PT at full reverse when moving material around. Not many places i can run my PT at full speed but when i can.... :D
   / Just ordered a PT-180, wanted to introduce myself #35
:chicken: (That is a chicken if you can't see it)
Yea fair enough about the pipe wrench :).
I hope to put an oil cooler on there at some point (probably after the warranty runs out), but if I keep seeing 180+ degree temps in under an hour of mowing, I'm just going to do it. I read the post where you did it, but I don't completely understand what hoses you re-routed. I'm assuming some of these are lower pressure return lines. I could "water cool" it for the summer too I suppose hehe. Just drive down by the lake and grab a bucket.
The oil light I got also has a audible warning. Havent tried it yet, and not sure how much im going to love hearing the beep every time I start it but I realized the same thing. If the pressure goes low, I want to know like immediately.
Thanks again for all the help everyone!
   / Just ordered a PT-180, wanted to introduce myself #39
If you are concerned about the warranty just zip mount a fan to the engine cover and gator clip the leads to the battery. Get that heat out of the tub. Help the Hydraulics indirectly. No intrusion required.
   / Just ordered a PT-180, wanted to introduce myself #40
The s/n are not necessarily chronologically sequential. I have numbers higher and lower than yours from a single purchase 7 years ago.
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
Enclosed Service Truck (A55788)
Enclosed Service...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2003 Big Tex 10PI...
2009 Honda odyssey (A55788)
2009 Honda odyssey...
