What year built?
/ What year built? #1
codger
Nead info on IH 275 diesle. Who made the motor ?
Is there a site with IH serial # ?
My 275 has devloped a motor noise, not good.
We have some poor dealers in my area, so I nead as much info on the machine as I can get before I let them
near it .
Thanks AL H. {codger}
/ What year built? #2
I tried a quick Google search. You might ask that question further down the main page on the Case-IH specific site.
/ What year built? #3
CaseIH 275
General tractor information:
Manufacturer:CaseIH
Model:275
Type:Farm/Agricultural tractor
Years produced:1986 - 1991
Total built:
Factory:
Original price:$13,100 (1991)
Tractor power:
Engine:31 hp [23.1 kW]
PTO (rated):27 hp [20.1 kW]
Engine:
Manufacturer:Mitsubishi
Fuel:diesel
Cylinders:3
Bore/Stroke:
Displacement:91.3 ci [1.5 L]
Compression:
Rated RPMs:
Cooling:
Torque:
Firing order:
Transmission:
Type:synchromesh
Forward:9
Reverse:3
Mechanical:
Chassis:MFWD optional
Steering:
Brakes:
Capacity:
Fuel:7.4 gal [28 L]
Coolant:6.3 qts [6.0 L]
3-Point Hitch:
Rear Hitch Category:I
Rear lift:1544 lbs [700 kg]
Power Take-off (PTO):
Rear PTO:live
Rear speed (RPM):540,1150
Hydraulics:
Type Open
Capacity:26.4 gal [99 L]
Total flow:
Outlet flow:7.3 gpm [27.6 lpm]
Pressure:
Outlets:1
Tires:
Ag front:6.00-16
Ag rear:13.6-24
Dimensions:
Weight:2600 lbs [1179 kg]
Wheelbase:71 inches [180 cm]
Length:
Width:
Height:
Ground clearance:
Electrical:
CaseIH 275 links:
Tractors from 1986-1989 had Nissan engines, later versions had Mitsubishi, according to Used Tractor Guide.
/ What year built? #4
Serial number located right front frame;
Year Beginning Serial #
1986 17656500
1987 17656510
1988 CCJ0028001
1989 CCJ0028615
1990 CCJ0029301
1991 CCJ0029992
1992 CCJ0030672
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
Metal John Deere Birdhouse (A65583)
Metal John Deere...
Gehl RS6-34 (A64119)
1990 FRUEHAUF 53' DRY VAN TRAILER (A65054)
1990 FRUEHAUF 53'...
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
