What would you make out of a semi brake drum?
   / What would you make out of a semi brake drum? #1
jimg
I scored a semi brake drum at the coop Tues and had a couple ideas of what Id like to put it to: 1) use it as the pedestal base for my bench grinder or 2) make a portable forage by filling it w/ refractory cement. Im sure it must be more useful than that....what would you use it for?
Maybe Ill broaden this question a bit...what sorts of great salvage stuff do you look for and what does it become after you find it? Im the type that brings back more from the dump than I take. Theres just too many great things that would be useful at some point. :)
   / What would you make out of a semi brake drum? #2
Lots of good things, burn barrel, attachment weight, rear tractor weight
and I could go on :D
   / What would you make out of a semi brake drum? #3
Sandblast down to bare metal and give it a real good paint job. Add some legs and you have a nice planter stand for your wife to use!!:D :D :D
   / What would you make out of a semi brake drum? #4
They do make a good base for a pedestal grinder. And the local high school marching bands use them as percussion instruments- really! I'd like to mess around with metal sculpture. I've seen some great stuff, such as angels with car vent windows for wings, and a huge (almost life-size) dinosaur made of car parts. The head and jaws were made from oil pans.
   / What would you make out of a semi brake drum? #5
Single Use Boat Anchor . :D :D
Fred H.
   / What would you make out of a semi brake drum? #6
Fred H.
Kool, who is throwing it out and a BETTER question !! Who is pulling it in :eek:
I like the yard display stand idea
and that 20 foot boat in my gallery is my next yard art !!
I'm not afraid to cut it up at all :D
Stay tuned for further Pictures, coming soon to theaters near to you
Jim
   / What would you make out of a semi brake drum? #7
I had a friend in CT that dragged home a free 24' fiberglass boat hull. He smoothed up the inside, sunk it in the ground, and had a 24' boat-shaped swimming pool!
Also though I might use it as the base for a small portable welding table.
   / What would you make out of a semi brake drum? #9
I have one that I use as a front weight on my tractor. I cut piece of metal mesh for the bottom, and bolted together. It doulbles as a place to put things.
Eddie
   / What would you make out of a semi brake drum? #10
That's pretty cool Eddie - You have a lot of good ideas !
UNUSED (2) 3500# DROP AXLE W/ BRAKES (A54756)
UNUSED (2) 3500#...
2007 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W97X154872 (A54865)
2007 Ford Crown...
2025 JMR 36in Mini Skid Steer Bucket (A53421)
2025 JMR 36in Mini...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2025 Swict 60in Bucket Skid Steer Attachment (A53421)
2025 Swict 60in...
2020 VOLVO VNL TANDEM AXLE SLEEPER (A54313)
2020 VOLVO VNL...
