What would you make out of a semi brake drum?
   / What would you make out of a semi brake drum? #1
jimg
I scored a semi brake drum at the coop Tues and had a couple ideas of what Id like to put it to: 1) use it as the pedestal base for my bench grinder or 2) make a portable forage by filling it w/ refractory cement. Im sure it must be more useful than that....what would you use it for?
Maybe Ill broaden this question a bit...what sorts of great salvage stuff do you look for and what does it become after you find it? Im the type that brings back more from the dump than I take. Theres just too many great things that would be useful at some point. :)
   / What would you make out of a semi brake drum? #2
Lots of good things, burn barrel, attachment weight, rear tractor weight
and I could go on :D
   / What would you make out of a semi brake drum? #3
Sandblast down to bare metal and give it a real good paint job. Add some legs and you have a nice planter stand for your wife to use!!:D :D :D
   / What would you make out of a semi brake drum? #4
They do make a good base for a pedestal grinder. And the local high school marching bands use them as percussion instruments- really! I'd like to mess around with metal sculpture. I've seen some great stuff, such as angels with car vent windows for wings, and a huge (almost life-size) dinosaur made of car parts. The head and jaws were made from oil pans.
   / What would you make out of a semi brake drum? #5
Single Use Boat Anchor . :D :D
Fred H.
   / What would you make out of a semi brake drum? #6
Fred H.
Kool, who is throwing it out and a BETTER question !! Who is pulling it in :eek:
I like the yard display stand idea
and that 20 foot boat in my gallery is my next yard art !!
I'm not afraid to cut it up at all :D
Stay tuned for further Pictures, coming soon to theaters near to you
Jim
   / What would you make out of a semi brake drum? #7
I had a friend in CT that dragged home a free 24' fiberglass boat hull. He smoothed up the inside, sunk it in the ground, and had a 24' boat-shaped swimming pool!
Also though I might use it as the base for a small portable welding table.
   / What would you make out of a semi brake drum? #9
I have one that I use as a front weight on my tractor. I cut piece of metal mesh for the bottom, and bolted together. It doulbles as a place to put things.
Eddie
   / What would you make out of a semi brake drum? #10
That's pretty cool Eddie - You have a lot of good ideas !
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
Test Button (A47477)
Loader Bucket (A53421)
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
UNUSED FUTURE FT15J EXCAVATOR (A54756)
UNUSED FUTURE...
