What would this be called?
/ What would this be called? #11
What I was thinking was dig the trench with something like that, then installing the pipe - not at the same time. I would guess it would take several passes to get the depth and maybe a little wider with each pass. That may beat renting a ditch witch!
You can get deeper with each pass, however, I doubt it will get any wider. It will just follow the same slot. A little manual Labor would go along way with the subsoiler. Ken Sweet
Gotcha Ken - much appreciated!
/ What would this be called? #13
My middle buster is half middle buster, half subsoiler. I use the subsoiler to dig up the area then used the middle busters furrower to clean out the trench or ditch. this gets it deep enough and wide enough to work in. I got my middle buster from General Implement. the cool thing is that it has a hole on top of it for a trailer ball so I can take the cultivator shank completly off and move trailers around. Very useful piece of equipment.
What is the deepest trench you can dig with that setup?
/ What would this be called? #15
It can dig up to 2 feet deep in softer soils and 1 foot on hard ground. If you added some weights to it, it will dig much better. Mine is so big that my Dad's JohnDeere 3720 can barely get it off the ground with a few inches of clearance. Obviously you would need a smaller one for your Yanmar. I have mostly used mine in gravel and rocky areas and have dug 1-2 feet down. I dug a ditch with it down the side of our driveway to control water run off from the natural spring runing through our property. It worked great for that. And it is also nice for pre tilling areas for a garden.:thumbsup:
/ What would this be called? #16
G'day we have the same over here but we call them single tyne rippers and most of them have a pipe laying attachment that will lay 2" poly pipe, the attachment is big enough to allow a joiner to pass through it making it very easy to lay long lengths of pipe in a single pass.
Jon
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
Nissan Forklift (A55973)
Nissan Forklift...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
2013 MACK CHU (PINNACLE) (A60736)
2013 MACK CHU...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
