What were your best "Macgyver fixes"?
   / What were your best "Macgyver fixes"? #1
NoTrespassing
Elite Member
East Central Illinois
Kubota 1999 L3710 HST FWA
I was having a conversation about emergency transportation fixes the other day and was wondering what other Macgyver fixes others had come up with. I will relate two of mine.
In high school a buddy and I were on a road trip in my early 70's Mercury Comet and the throttle cable broke right inside the firewall. The only tool in the car was a pair of needle nosed pliers. I laid on the floor pulling the cable as by friend drove the car and relayed instructions. It was pretty hilarious and we managed to make it the 10 miles home that way. After finding out is was a dealer part and would take 2 weeks to arrive, I pulled a piece of bailing twine though the firewall and tied a stick to it. I drove it back and forth to school that way for 2 weeks until the cable arrived.
Another quick story about a Macgyver fix; While trying to back out of a bar parking parking lot in my 71 Bronco, the clutch pedal made a loud bang and went to the floor board. Upon inspection I realized the pin holding the linkage to the pedal was gone. I couldn't find the pin or cotter key so I took my key ring apart and looped it through both holes in the linkage and pedal and drove it home.
OK, what crazy Macgyver stories do you all have?
Kevin
   / What were your best "Macgyver fixes"? #2
I have VW Dune Buggy, Meyers Manx style... Throttle cable broke one day... So I pulled it out of tube in chassis, tied it to carb linkage and ran it forward, uses left hand (over shoulder) to operate throttle and right to steer and shift gears....
Real fear was if I left it beside road and hiked into town to get parts it would not be there when I got back...
Dale
   / What were your best "Macgyver fixes"? #3
I too had a throttle cable break on me. Ended up taking my shoelaces off, tying them together. Ran one end through the firewall and tied it to throttle linkage. The other end I pulled on to make it go. That was scary.
   / What were your best "Macgyver fixes"? #4
Had an alternator belt break (back in the 70's) while out on a date, convinced her to give up her pantyhose to use as a temp fix. Got us through the night,
   / What were your best "Macgyver fixes"? #5
Can't call this a MacGyver fix as it happened in the 60's before he was around. Driving a 62 Volvo, a wire on the generator broke off and it quit charging. While trying to reattach it, the stud was turning and I knew that wasn't good so I installed a small alligator clip on the wire and and used that to reattach it. Drove like that for several years until the generator needed other work. It would fall off occasionally and I would just stop the put it back on.
   / What were your best "Macgyver fixes"? #6
I was headed into the woods with my '84 F150 when it suddenly quit. Before somebody came along to give me a ride I determined that the distributer wasn't turning, so I pulled it out and found that the roll pin holding the gear to the shaft had worn through.
There was no auto parts or hardware store nearby so I got hold of a nail that was just the right size, rounded it over on each end and put it back together. That nail was still in place when I sold the truck.
   / What were your best "Macgyver fixes"? #7
It was the original release of Mash in Ft Wayne, back when you wore a coat/tie to see a movie. Front lot was full so we parked my 68 Camaro behind the theater where it was darker and less traffic. Afterward, I did not even get out of the parking space before I heard and felt the most awful racket in the rear.... Anybody?
Turns out, someone had tried stealing my mags- removed 4 lug-nuts on the first wheel but gave up on the locking lug-nut. (Must have been his first rodeo) Jacked it up, removed one lug-nut each from the other three wheels, and limped home with 4 lugs per wheel.
Probably wore those same clothes to church in the morning.
   / What were your best "Macgyver fixes"? #8
All of the throttle cable breaks reminded me of my non-Mcyver fix for that problem. I turned up the idle on my 4x4 with a standard transmission and proceeded to travel the 4 miles home at a slow speed. There was a long steep hill enroute and I had to drop it into low range. I was traveling at the speed of a slow jog, so I jumped out and pretended to be pushing it up the hill. Got a lot of looks of amazement as cars drove by.
   / What were your best "Macgyver fixes"? #9
I had a 1995 full size Chevy van with a wheelchair lift. The motor for the lift went bad and a replacement was $1000.
I took a spark plug socket on a cordless drill and spun the motor shaft up and down. I had to build up the shaft with duct tape, so that's a true McGyver.
Ran it that way for several months.
   / What were your best "Macgyver fixes"? #10
Is there a first prize gift?
In 1982 I bought a new VW diesel rabbit pickup truck. Way away from home the fuel filter sprang a major leak and it shut off.
Late at night, nothing around except wife and I passed a Wendy's and a convenience store. The Wendy's was closing but I went around back and a kitchen worker gave a 5 gallon pickle bucket. Across road at convenience store I bought 5 gallons of kerosene. I put this in bed of truck, then removed the windshield washer hoses, and emptied the reservoir. I filled it with kerosene and all that tubing was enough to run from bucket to washer pump, out to injector pump. It worked. I would drive along, when it stumbled I ran washer pump. It made it all the way home, the truck cut off in driveway. The bucket was completely empty but it got us home.
   / What were your best "Macgyver fixes"? #11
Set the points using a hacksaw blade as a feeler gauge along the side of the Alaska Highway. I had hit a pothole so big it shook the points out of adjustment and the engine quit. This was 30+ years ago when cars still had points.
   / What were your best "Macgyver fixes"? #12
quicksand farmer - - you were lucky. When we went to Alaska permanently in 1965 - driving a VW up the Alaska Hwy - drove into a pothole - got lost - never been heard from since.
Four wheeling in Alaska. Something UKN tore the rubber "bungie cord" that held the exhaust pipe. Several wraps of household aluminum foil around the tail pipe and a goodly amount of duck tape got us to where a fellow member donated a wire coat hanger. The reason I even remember all of this - the stupid replacement OEM bungie cord - - $17.95. This was in 1970.
   / What were your best "Macgyver fixes"? #13
I had an aviation business based at Montreal airport.
A Cessna owner came to us with his throttle control in his hands.
They are typically 'push pull' devices very like a choke cable only heavier gauge. Since parts would be a waiting game I resorted to using a HD (but correct sized) stiff wire that was actually a piano wire. (don't ask what key, do re mi or ??)*
For the pilot we heated and formed a ring so that he could grab and push/pull like the real thing, only instead of a big knob he had about a 2" coil or ring to grab.
*crazy, but think it was 80 thou/inch
   / What were your best "Macgyver fixes"? #14
That sound's like a con job to me. Wish I'd thought of it when I was a young feller.
   / What were your best "Macgyver fixes"? #15
Salty Sea Ditty (Sailor story)... [early 1990's] I was the radar tech on a Navy Tanker/Supply ship {Important NOTE: a mixed gender crew} and was called to the bridge around 0330 (as is always the case :laughing:) for a joystick problem on the pedestal mounted radar display. The officers seemed to think that the harder they pushed on the joystick, the faster the 'cursor' would go on the display. No, but that didn't stop them from stripping the metal thread of the joystick shaft where it went into the X/Y unit. They also managed to ruin the rubber 'shaft protection/dust cover'. Naturally there were no spare parts onboard and we were in the middle of the Pacific + a week or so from the next port-of-call.
Fixing the shaft to the X/Y was a simple matter of epoxy cement... but I needed to replace the dust cover so that nothing would drop down into the guts of the display. I knew of a piece of soft leather that I could cut as a 'gasket' and also cut an "X" in the middle to allow the joystick to move in the X/Y plane but I still needed something for the shaft of the joystick... something 5-6" long, flexible, open at one end and closed at the other... :scratchchin:
So (0530) I was knocking on the Medical Officer's cabin door and asked a very sleepy Surgeon LEUT for a condom. He surreptitiously looked around to see if there was anyone of the female persuasion with me whilst asking why I needed this particular item at this specific time of the morning. I explained, he thought a moment and then asked if a non-lubricated latex finger glove would suffice. Perfect! Thank you Sir.
The fault was fixed. I asked that the bridge officers refrained from 'cranking' on the joystick ("Use a slow touch and an easy hand.") and the jury-rig lasted fine until a replacement arrived weeks later.
   / What were your best "Macgyver fixes"? #16
I wasn't quite sure what, "got us through the night meant myself".
   / What were your best "Macgyver fixes"? #17
I've got a bunch of em' but i think one of my best was of course another broken throttle cable but this one was on my 1976 Mercury Trailtwister 340. The end at the throttle block broke off leaving me with no throttle and we had just unloaded to ride for the day at our family farm. I looked around for a solution and we had a old burned out house on the farm that had some old light switches. I took one apart and used the wire clamping end for where you'd put the wires to it. I took that piece and clamped my cable and reassembled the throttle and rode it like that for two weekends till I got the new cable from my "Buddy Bob" in Wisconsin at the Mercury parts place.
Was one of my best fixes but there's a lot of others. Another good McGyver move was on our Chinese Farmpro 2420 tractor. The alternator blew and I wasn't messing with the junk chinese electrics on it (as they were pretty bad). I replaced it with a 727 alternator from a 74 chevy something or other for $35 it was a three wire version so I needed some connections. Put it together and found I needed more clearance due to the belt and pulley differences on the old one. The new one already had the pulley on it so I wasn't messing with that and I looked around in the barn again for something that might work. I ended up using the latch side of a barn door lock for the stalls. Just a short piece of metal that had two holes and allowed the belt to extend and mount the new alternator up. Worked perfectly and is still on the tractor today close to 10 years later.
Steve with lots of McGyver fixes over the years. I even called some of them that when people would ask about some of them I did at work. I had several on some early versions of Laser printers that had engineering bugs in them.
   / What were your best "Macgyver fixes"? #18
After tiring of trying to stir 100% peanut butter (with the oil) I gave up and chucked my wife's portable mixer dough hook in my Makita drill. In 30 seconds I had creamy PB with no effort. I did a thread about it with pics on the TBN. You have to run the drill backwards and start slow or PB will be everywhere.
   / What were your best "Macgyver fixes"? #19
The cover of most paper match books was .018...used to see many tune up mechanics starting there...hardly ever saw an actual feeler gauge...or a dwell meter...
   / What were your best "Macgyver fixes"? #20
Driving my service truck across east OR in the middle of the night, and no traffic. The fuel gauge was on the fritz so I ran out of gas out in nowhere 50 miles from any thing. Scrtached my head a little plus another location. Hooked up the O/A welding outfit and stuck the Acet hose in the carb. Started at real low flow and tried to start up, it worked, ran fine. Set the O/A set wher I could reach the regulator handle. Started up again and controlled engine speed with the regulator. Afraid to get going too fast so limped along at 30 MPH to the next town.
I am not sure I did a very safe thing, it could have all blown up on me. My guardian angle was stronger than Ole Man Murphy that night.
Ron
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2020 CATERPILLAR 289D3 SKID STEER (A60429)
2020 CATERPILLAR...
2013 Nissan Juke SUV (A59231)
2013 Nissan Juke...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
