What tyre pressure
/ What tyre pressure #1
Tractor 2202
Boston UK
Iseki ts2202
I have an Iseki 2202 4wd with front loader and agri tyres, can someone tell me what pressures I should be running in the tyres
/ What tyre pressure #2
Usually recommended tire pressures are marked on the side walls of the tires.
For loader work I recommend the maximum pressure listed. On mine I run about 40-45 PSI in the fronts and 18-20 in the rears.
Yours may vary depending on tire size.
/ What tyre pressure #4
Ditto. Read the sidewall of the tire
/ What tyre pressure #5
I've read that, like stated above, you want your fronts at the max. pressure shown on the sidewall: that should be their greatest load-bearing, and adjust the rears so the tread is flat against a flat surface. Somebody, maybe the guy at Everything Attachements (?) demonstrated how they do that.
40' High cube 6 door Single use Shipping Container (A64194)
40' High cube 6...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
Hercules Gun Safe Holds 20 Guns (A65583)
Hercules Gun Safe...
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
213089 (A64276)
213089 (A64276)
2022 EZ-GO ELITE...
