What to look for on a IH 706?
   / What to look for on a IH 706?
Well I took the plunge and bought it for $2900. It does have some blowby, slight oil smoke, and some antifreeze coming from somewhere at the back of the engine (oil is not milky, antifreeze is green). It has 6900 hours (282 diesel) and it will likely need some work. Everything else seems to work good.
I plan on using it to do some mowing this fall until I can start a midwinter investigation. It seems to be put together well, with heavy connections. Shifting is bit sloppy, another thing to check.
Hopefully I can find a loader for it somewhere.
What repair manual would be the best to start with?
   / What to look for on a IH 706? #12
You could have a head gasket leak. That's not to uncommon for them at those hours. The shifting is quite simple and should be easy to look at and see which knuckles are loose.
Good Luck!
   / What to look for on a IH 706? #13
Congrats. That sounds like a fair price. I put an older model farmhand loader on mine a few years back and have gotten lots of use from the combo.
Valent,
Whats a fair price for an older loader like yours?
   / What to look for on a IH 706? #15
I have no idea. I bought mine at an equipment auction in very good shape for around a thousand or $1200 and spent about $400 to build a connection to the tractor. I could have ordered(maybe) the connection for less but only found that out much later. Knowing what I know now, I would easily pay 3,000 for the same. I guess I was so lucky and didnt even know it.
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
John Deere 5075E (A53317)
John Deere 5075E...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60460)
2017 Peterbilt 567...
2011 CATERPILLAR CP56 PADFOOT ROLLER (A60429)
2011 CATERPILLAR...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
