What to do with a gravely Blade?
   / What to do with a gravely Blade?
Is that sidehill, or up/down? Good to know the stats, it definitely affects which I'll use.
   / What to do with a gravely Blade? #22
Any direction as the T-head Gravelys pick up the oil from the tranny and pump it into the engine, High/Low planetary, and any excess goes to the front of the tranny. On early T-heads, the oil was also slung by the flywheels everywhere in the engine as they were wet sump and the oil filled the engine up to the level of the shifter rod holes for the rear planetary set. Later T-heads had holes at the bottom of the crankcase front to drain the oil back into the tranny.
Only problem with steep grades is the angle of the carb. More of a problem down hill than side of the hill.
2007 INTERNATIONAL SF625 BUCKET TRUCK (A50854)
2007 INTERNATIONAL...
Heavy Haul trailer (A49461)
Heavy Haul trailer...
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A51222)
LINK BELT LB-98...
