What to do with a gravely Blade?
   / What to do with a gravely Blade?
Is that sidehill, or up/down? Good to know the stats, it definitely affects which I'll use.
   / What to do with a gravely Blade? #22
Any direction as the T-head Gravelys pick up the oil from the tranny and pump it into the engine, High/Low planetary, and any excess goes to the front of the tranny. On early T-heads, the oil was also slung by the flywheels everywhere in the engine as they were wet sump and the oil filled the engine up to the level of the shifter rod holes for the rear planetary set. Later T-heads had holes at the bottom of the crankcase front to drain the oil back into the tranny.
Only problem with steep grades is the angle of the carb. More of a problem down hill than side of the hill.
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
2016 CATERPILLAR 325FL EXCAVATOR (A51242)
2016 CATERPILLAR...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A51039)
John Deere 6105E...
2015 FORD F750 26FT BOX TRUCK (A51219)
2015 FORD F750...
2018 PETERBILT 567 (A50854)
2018 PETERBILT 567...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
