What to do with a gravely Blade?
   / What to do with a gravely Blade?
Is that sidehill, or up/down? Good to know the stats, it definitely affects which I'll use.
   / What to do with a gravely Blade? #22
Any direction as the T-head Gravelys pick up the oil from the tranny and pump it into the engine, High/Low planetary, and any excess goes to the front of the tranny. On early T-heads, the oil was also slung by the flywheels everywhere in the engine as they were wet sump and the oil filled the engine up to the level of the shifter rod holes for the rear planetary set. Later T-heads had holes at the bottom of the crankcase front to drain the oil back into the tranny.
Only problem with steep grades is the angle of the carb. More of a problem down hill than side of the hill.
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
2013 Ford F-250 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
STORAGE FEES (A51222)
PHENIX TECH HI POT MACHINE (A50854)
PHENIX TECH HI POT...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
