What to Buy
/ What to Buy
I am 90% sure I am going with the Kubota. However, now I am not sure what Model. :) When looking at all these posts about HP and weight, I have my eye on the M9540 4WD with Cab. My wife says I occassionaly suffer from "trying to lenghten my manhood with bigger toys". :) Is the 9540 too big compared to the 7040?
/ What to Buy #42
Often the "awards" are given based on money that changes hands. Like the Car&Driver car and truck of the year awards. Based on dollars changing hands more than anything else. I'd take all those awards with a shaker of salt.
Now, if the companies would open the books and show us exactly how many warranty claims were made for each model with sortable details on what broke, time to repair, time for parts, and total cost..... Also, it would be good to know what spare parts are being ordered, so we can figure out what is breaking. But, companies don't share that pertinent information!
Still, even with all the customer loyalty exhibited here, I would still buy Kubota first and Deere second when basing the decision on factors like 1) quality & reliability, 2) features, 3) long term support, 4) long term value. Other view points and opinions are still valid, but that's what I would do....
jb
On edit: The 9540 is a great machine. It is larger than the 7040, but "too big"? That's subjective. Some would say it's only too big if you can't turn it around on your property. I would think that it would be a good choice for what you want to do. The bigger machine will have a larger more comfortable cab and be more productive, but will use more fuel doing it. All a balancing act.... From the Kubota web page, the 9540 is only a foot longer than the 7040. Quit diddling around and order it already!
jb
/ What to Buy #43
I like the Kubota M series. I don't think I would buy the 7040 model though, I'm sure it's a fine machine, but here's why. The next step up in the Kubota lineup, for "just" a couple thousand dollars more, is the M8540. The 8540 and 9540 are bigger more capable machines (longer wheelbase, more lift, more power, more weight, more hydraulic flow, etc).
I also thought the 8540/9540 machines would be too big. I test drove the 7040 and the 9540 and found I was comfortable with the 9540 and was surprised at how manueverable it was. You should test drive both of them.
A couple of guys here on tractorbynet have traded from a 7040 to the 8540.
So for me, if the 6040 was not enough tractor I'd probably skip the 7040 and look at the next size up.
/ What to Buy #45
jb
jb
"JB"...Very well stated; that has always been my belief too!! Contributions embellishing the decisions?
/ What to Buy #46
Someone mentioned that larger equates to more fuel burned. That is not always the case. Larger equates to faster and or lower RPMs for the same work. Manytimes it is much more fuel efficient to run a larger tractor at lower RPM compared to a small tractor at full throttle to accomplish the same work. Bush hogging might be the exception to this unless you have a 2 speed PTO. I once many years ago used my 9000 Ford to bushhog using the 1000 RPM shaft with an adapter. Ran the tractor at half throttle, had plenty of power and ran as fast as I cared to. Tractor actually used less fuel than our 65 HP tractor would have doing the same job. Just have to watch the RPM to make sure you dont burn up a gearbox.
JUST and Observation for consideration.
/ What to Buy #47
One last thing, and it sounds like it won't matter anyway, but your 3 point implements for that 9540 are going to be a lot more money and you will have fewer places to get them, than for a smaller tractor.
Just food for thought.
/ What to Buy #48
How many acres are you farming again? It seems to me your looking at a lot of tractor for 60 acres.
/ What to Buy #49
Actually, both of his choices, the 7040 and 9540,are cat 2. It's not like his choice is between a 24 hp "B" series or the M9540!
Yes, the 9540 is able to be used on larger pieces of property, but it will be just fine on 60 acres. Spacious cab, excellent turning radius, plenty of power for any task. If I could afford one, I'd get one! (maybe he can reward my advice and get a price break by purchasing 2? )
/ What to Buy #50
Just my opinion, for your hobby farm I agree with the wife. Although if money is no option go bigger....
/ What to Buy #51
While they are both cat 2 in size, an implement that is ok to use with the 7040 simply would not hold up on the 9540. All implements will need to be heavy duty- commercial grade to be able to withstand the weight and power of the 9540. Sort of like comparing a medium sized cat 1 (35hp) to a larger cat 1 machine (50hp). They don't need the same quality of implement to hold up.
/ What to Buy #52
True Story on tractor selection:
I often wonder how many people on here that give adivice have actually have driven or used all three tractors your considering. I know many are brand specific and die hard with one brand or a dealer. If your like me I buy the best for the money. My fultime job is a government job which supports my supports my farming program. I was just helping a local organization that was in the process of buying a new tractor. Along with me were 5 other farmers helping select the tractor. We looked at Deere, Kubota, Montana, and NH. This was govt money so as you know we had to take bids. However, we don't have to recommend the low bid if we give reasons why we chose a higher bid. Things like better dealers, parts etc... So really you can always justify why you bought what you did most of the time. When we got the bids back it went from highest to lowest, Deere, NH, Kubota, Montana. Just like many of you probably would have projected. One of the reason we got a quote for the Montana was because I own one. They all laughed at me. After getting the quotes we sat down and decided to look at the Kubota and Montana and toss the higher bids out. We figured they couldn't come down low enough and after asking they couldn't. Our first meeting, before test driving, I was the only one who was at all considering the Montana. Again they gave me a hard time. Several were Deere owners themselves. We all took off a day of work and went together to test drive the tractors. To make a long story short, after test driving both tractors, these gentleman selected the Montana 4-1 over the Kubota. 5-1 if you count me. The gentleman who selected the Kubota said he liked the Montana better but was leary of dealer stability. I didn't even vote. One of the fellows is a former offensive line college football player about 6' 280lbs, got on the Kubota the metal and deck actually bowed down noticably to the group as he got on. We didn't notice this with the Montana. Each took about 15 minutes driving both tractors, so we spent the whole day out there. It was a fun time. They ended up purchasing the Montana 4940 with FEL and ROPS after a group of 5 farmers test drove the machines. Last I heard they are very happy with it and are still talking to the five farmers that helped.
My recommendations is for everyone. Go test drive all these machines and see what fits your fancy. All have their own pros-cons. Those who have an open mind might be surprised. There is really no wrong or right, you just have to be happy with your tractor.
/ What to Buy #53
I wouldn't even consider buying a tractor out of a selection of tractors without a test drive.. that's like tractor buying 101, page 2..
soundguy
/ What to Buy #54
If you really want to put a twist in tractor selection. I think the Montana T7074 has the Deere engine. Best of both worlds now...
I haven't had the opportunity to test out one of these yet.
/ What to Buy #56
Good point.. Must be tractor envy......cause I couldn't talk wife into letting me get the bigger one..
/ What to Buy
Unfortunately I had to jump back into my day job for a couple weeks. I am actually going down this weekend to talk with the dealer.
/ What to Buy #59
soundguy
This is how I ended up with a Kioti, they weren't even a consideration until I drove one and compared features.
/ What to Buy #60
Same with my Montana 5740C. I've heard good things about Kioti, what size did you buy and how do you like it?
5x10 Utility Trailer (A61165)
5x10 Utility...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
KUBOTA MS-111 TRACTOR (A62130)
KUBOTA MS-111...
New/Unused Landhonor 11ft x 19ft Carport with Open Side Walls (A61166)
New/Unused...
2013 Ford Escape SUV (A61569)
2013 Ford Escape...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
