What spray lube do you like?
   / What spray lube do you like? #81
I have been using Lubriplate Chain and Cable lube for many years now.
   / What spray lube do you like? #82
PB Blaster seemed to change the formula years ago, and I have not had much luck with it since. It used to sizzle after you sprayed it. That's no longer the case.
I have tried many penetrating oils, and some do better at some things than others.
To protect surfaces, I like Fluid film or Corrosion Free. Wool Wax would be similar, but I've never tried it. These products stick around after you spray them and are great from a protection standpoint. My truck has been sprayed with Corrosion Free for 7 years. The underneath it looks the same as the day I purchased it, and there is plenty of salt here in the winter.
For freeing rusted parts, Sea Foam Deep Creep works well and works better with some heat. Schaeffer's Penetro 90 has also worked well. In my limited use of it, Liquid Wrench seemed like a good product, as did Texas Refinery Corporation Super-EEZ penetrating oil.
The worst penetrating oil I have ever used is regular WD40. Ballistol works so much better as a jack of all trades penetrating oil, cleaner, and lubricant.
   / What spray lube do you like? #83
You have to give WD-40 some credit, though.
Tons of that inferior product are still being sold, for some reason. Bad habits are hard to get away from, I guess.
   / What spray lube do you like? #84
Maybe because of the price. At $20+ the good lubes are a bit more expensive.
   / What spray lube do you like? #85
I use the original for parts cleaning and contact type for drying my trailer plug.
   / What spray lube do you like? #86
I was at the store the other day looking for some lube..
They had the usual WD40 and such..
THEN I saw some:
KNOCK’ER LOOSE..
I asked the old fella behind the counter if it was any good.. he said, for 9.00 it autta be..(lol)
I tried it.. OMG FELLAS.!!! I’ll never use anything else again.!!! It is FANTASTIC..
   / What spray lube do you like? #87
For lube - motorcycle chain spray lube. For cleaning - WD40.
   / What spray lube do you like? #88
I use Fluid Film for lubrication. I use WD 40 to remove rust or to free up rusted things.
I have to agree... Fluid Film for lubrication and WD40 for a multiple of uses ie: key switch lube, rust removal, glue removal, etc. Somewhere out there there's a list of 101 things to do with WD40. But fluid film has been the best for general lubrication to date!
   / What spray lube do you like? #89
Tri-Flow.
My draft inducer fan gummed up and stopped working after about 5-7 years on my furnace. Talked to HVAC installer and he said they had alot of problems with that motor and a new one was $300 and it wasn't compatible with control board and would need a new $300 controller. I said that's ridiculous. I could tell it was just gummed up not bad bearing or anything. I had a can of Tri-flow my dad had given me about 15 years prior. Needless to say, I'm still running furnace on same motor 13-15 years later. Made a believer out of me. I use it everywhere I used to use WD40 and it is 100 times better. I think it's like a bike chain lubricant and leaves a Teflon coating. Surprised the bike guys earlier didn't mention it.
PB blaster makes a product like Fluid Film. Supposed to last longer. I'm going to try it this fall as an undercoat protectant.
I like Kroil for a penetrating oil also, but PB blaster works well also, but I think Kroil works better.
   / What spray lube do you like? #90
Use to swear by Kroil but they have totally out priced it. Have switched over to PB Blaster. Works great
(5) CANDY JARS (A58374)
(5) CANDY JARS...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
CASE INTERNATIONAL 3950 - 21' DISC HARROW (A52708)
CASE INTERNATIONAL...
Carolina 30-Ton Capacity Shop Press w/Pittsburg 20-Ton Jack, Model CP100, S/N 04020 (A59076)
Carolina 30-Ton...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
