ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,727
- Location
- America's Dairyland
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
I have been using Lubriplate Chain and Cable lube for many years now.
Maybe because of the price. At $20+ the good lubes are a bit more expensive.You have to give WD-40 some credit, though.
Tons of that inferior product are still being sold, for some reason. Bad habits are hard to get away from, I guess.
I use the original for parts cleaning and contact type for drying my trailer plug.You have to give WD-40 some credit, though.
I have to agree... Fluid Film for lubrication and WD40 for a multiple of uses ie: key switch lube, rust removal, glue removal, etc. Somewhere out there there's a list of 101 things to do with WD40. But fluid film has been the best for general lubrication to date!I use Fluid Film for lubrication. I use WD 40 to remove rust or to free up rusted things.
actually WD40 was made by 2 guys in a garage for Nasa. it was for spraying & lube on space craft that would lube even under high tempt's. then later on sold to the public. I keep rust buster for the rust penetrating spray, spray silicone for lubricating vehicle door weather stripping & on AC Orings, & WD 40 for everything in betweenThe world seems to default to WD40 for all spray lubricant applications. But I don't think it was even supposed to be a lubricant, it was supposed to displace water (I read that they were trying Water Displacer formulas and the 40th trial worked really well, hence WD40).
I'm going back to LPS1 for lighter lubrication and LPS2 for heavier. I had to order it, whereas you can practically get WD40 at convenience stores. But it is designed for lubrication.
I'm sticking with WD40 for displacing water, for example on the battery maintainer plugs and sockets.
For preventing rust, I like Fluid Film, which is wool wax in a spray can.
What do you think? Hmm, this would make a decent poll....
Are you certain of that?WD-40 is primarily fish oil. All natural and among the most universal products out there…rust, loosening, mild lubricant, grill cleaner, fish bait enhancer,,,the list is almost endless. And yes, it won’t hurt you if you unintentionally get some in your eyes or mouth. Whether it’s right or not for your application is the only question.
I’m late to the conversation, but if this helps…The world seems to default to WD40 for all spray lubricant applications. But I don't think it was even supposed to be a lubricant, it was supposed to displace water (I read that they were trying Water Displacer formulas and the 40th trial worked really well, hence WD40).
WD-40 can be a "mild" lubricant or work to "loosen" thickened oil or grease in joints.The world seems to default to WD40 for all spray lubricant applications. But I don't think it was even supposed to be a lubricant, it was supposed to displace water (I read that they were trying Water Displacer formulas and the 40th trial worked really well, hence WD40).
