What spray lube do you like?
/ What spray lube do you like? #101
"Spray Lube" or "Rust Buster"?
For rust busting I used to use Kroil, but the price has gotten outrageous.
I've started using a 50/50 (or so) mix of Acetone and ATF. I have some old Sure Shot sprayers that I refurbished and use, one with a long nylon flex hose.
Works quite well, better so far, than Kroil or anything else I have ever used. I would avoid getting it on a any painted surfaces you like the looks of though.
Someone suggested trying Marvel Mystery Oil instead of ATF. I may try that next time I mix some up.
For rust prevention/stopper, such as chassis/suspension parts, an old Jeep person told me about using a 50/50 mix of USED engine oil and USED ATF as a spray or wipe on. "used" probably for frugality as it's "Free".
Still using Wool Wax though for that.
/ What spray lube do you like? #102
You have to give WD-40 some credit, though.
Tons of that inferior product are still being sold, for some reason. Bad habits are hard to get away from, I guess.
I think it comes down to this: trouble almost never arises from failing to use the best spray lubricant. Nearly all troubles that can blamed on lubrication come from a complete lack of it, and almost never your specific brand choice.
/ What spray lube do you like? #103
WD-40 is primarily fish oil. All natural and among the most universal products out there…rust, loosening, mild lubricant, grill cleaner, fish bait enhancer,,,the list is almost endless. And yes, it won’t hurt you if you unintentionally get some in your eyes or mouth. Whether it’s right or not for your application is the only question.
About the fish oil, how do you know that? Isn't the formula secret?
And what in the world is "fish oil"?
/ What spray lube do you like? #104
/ What spray lube do you like? #105
As a side note, best thing ever for rust is Mystic Metal Mover, normally used for metal drilling lube. Best thing I have ever used For rust.
/ What spray lube do you like? #107
I dunno. When dealing with the 1-1/4 diameter bolts that hold the loaders in place on my backhoes, I think the effectiveness of the penetrating oil can be crucial.
Those bolts are also pretty much a worst case scenario, being threaded in from the bottom and then having about an inch worth of hole above the end of the bolt, where water dirt and such collects.
Add to that that they may not have been removed in 30+ years, and I want the best possible liquid applied, before hitting them with the hydraulic impact, which is good for 2,500 ft.-lbs.
Breaking one of those bolts would put a damper on my day.
/ What spray lube do you like? #108
John Deere all purpose lubricant spray - I know i might be paying for a name here but I tried other brands and I find the JD MP the best.
/ What spray lube do you like? #109
I have been spraying Blaster silicone spray on everything. I love that stuff.
/ What spray lube do you like? #110
The absolute best is "Strike Hold" no holds barred. No pun intended
/ What spray lube do you like? #112
Liquid Wrench or Graphite spray, depending on the application.
I like WD40 for cleaning up rusty stuff and "pushing" water out of wet mechanisms (like vice-grips left out in the rain); but for true "Lubrication": not so much.
In the dusty corners, I recall a reliable source telling me NOT to use WD40 on electrical contacts. It leaves a film that interferes with electrical conduction, thus making the contacts unreliable (I think this is temporary, but annoying nonetheless). Also, until it dries, WD40 can be highly flammable, so do not use it to do anything to the innards of a distributor (POP!! scratch one distributor cap)... first hand experience.
Further, I find that WD40 has a tendency to "dry out" joints, like maybe it dissolves what little lubricant may have been there. So, an oil will need to be applied later, anyway.
My preferred go to for easy lube where dirt wont be a problem is liquid wrench. It is also excellent for freeing rusty stuff. I've salvaged many "rusted up" tools with it. Much like WD40, however, I find that a true "lubricant" (like machine oil or grease) often needs to be applied not long after Liquid Wrench has done its job.
On things like open jackscrews and scissor jacks (think RV stabilizers), where dirt/grit attraction/retention is a problem, I like a graphite spray. It will stain concrete (and probably just about anything else), so use it somewhere you don't care about staining or put down some disposable sheeting under the treatment area.
I'm intrigued by the liquid film mentioned here...never heard of it...must check into that. Might be a good alternative to graphite.
/ What spray lube do you like? #113
Hands down the best electronics contact cleaner is DeoxIt. Stuff is amazing. I use the cleaner all the time on pots that are crunchy and cause static, follow it up with the fader lube to avoid damaging the pots coatings. From audio repair to auto repair the stuff is awesome. I keep the D12, fader lube and Gold all on hand.
/ What spray lube do you like? #114
Been using this since my dad handed me a can (older style) 40+ years ago, to clean a misbehaving type-O22 Lionel track switch. I probably still have that very can, in addition to several newer, the damn stuff lasts nearly forever.
/ What spray lube do you like? #115
Back in the days of White Farm Equipment they had one of the best penetrating oils you could find. It was supposed to contain Moly (still don't know how they got her in the can?). I had tried many different brands but that was the only one that did not dry up if left overnight, it was still wet the next morning. Unfortunately WFE went like a lot of other farm equipment manufacturers of the time and it is gone. Often wish I could have found out who made it for them.
/ What spray lube do you like? #116
Most of the alternative products I have seen mentioned in this post are not available here in France but good old WD40 certainly is. There are alternative lubricating sprays here and they have their place of course and a tube of silicone grease is indispensable especially for pool valves and plastic screw connections but I find WD40 is really multi functionable. For example, getting those stick-on labels off cleaning stains off some kinds of leather and, would you believe it, spray it on a wasp sting immediately and it stops it stinging.
I must get out more, sorry chaps.
/ What spray lube do you like? #117
WD-40 did work really well at getting the pine sap out of my living room carpet one Christmas when I was taking out our real tree and lost my balance and planted it in the middle of the living room. Then just soap and water to clean up the WD-40 spot.(y)
I used it frequently on one old car and never had anything happen.
/ What spray lube do you like? #120
I don’t think that is the correct spelling. But it’s in a orange can and it has some pretty good properties as far as soaking breaking stuck pieces apart. I have witnessed it
2022 John Deere 1025R (A53317)
2022 John Deere...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
INSPECTION (A61165)
INSPECTION (A61165)
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2016 BOBCAT E35I EXCAVATOR (A60429)
2016 BOBCAT E35I...
