What size shear pin should I use?
/ What size shear pin should I use? #1
atcNick
Bronze Member
Longview, Texas
Still shopping
I have a 30hp kioti tractor and a 5ft house brush hog. Broke my shear pin for the first time and I’m not sure what size pin I should replace it with.
/ What size shear pin should I use? #2
If I remember right:1/4"x4" grade #2 bolt.Do not use grade 5 or 8.
/ What size shear pin should I use? #4
TSC sells a 4 pack of shear bolts and nuts that’s pretty cheap if you shop there. Comes in a retail pack with heat shrink plastic over cardboard so you can peel one off and then hang the remainder on a pegboard or toss in a tool box and have them together and clearly identified as to what they are....vs random loose hardware that accumulates.
/ What size shear pin should I use? #5
Standard bolt 1/2"x 4" or 4.5" . Tractor supply sells them by the #.
/ What size shear pin should I use? #6
Replace it with one that fits tightly in the shear pin hole whatever size that might be. There should be no slop in the shear pin, a tight fit is critical
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2004 John Deere 8320 (A63688)
2004 John Deere...
2015 Hagie STS 12 Sprayer (A63111)
2015 Hagie STS 12...
EZ Trail 3400 (A63688)
