What size shear pin should I use?
/ What size shear pin should I use? #1
atcNick
Longview, Texas
Still shopping
I have a 30hp kioti tractor and a 5ft house brush hog. Broke my shear pin for the first time and I’m not sure what size pin I should replace it with.
/ What size shear pin should I use? #2
If I remember right:1/4"x4" grade #2 bolt.Do not use grade 5 or 8.
/ What size shear pin should I use? #4
TSC sells a 4 pack of shear bolts and nuts that’s pretty cheap if you shop there. Comes in a retail pack with heat shrink plastic over cardboard so you can peel one off and then hang the remainder on a pegboard or toss in a tool box and have them together and clearly identified as to what they are....vs random loose hardware that accumulates.
/ What size shear pin should I use? #5
Standard bolt 1/2"x 4" or 4.5" . Tractor supply sells them by the #.
/ What size shear pin should I use? #6
Replace it with one that fits tightly in the shear pin hole whatever size that might be. There should be no slop in the shear pin, a tight fit is critical
Generator (A61572)
Generator (A61572)
Adams 8 Ton Blender (A63688)
Adams 8 Ton...
1063 (A63291)
1063 (A63291)
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
