Bought a 1955 Ford 640. Tractor has been restored and engine runs very strong. According to tractor data the 640 puts out 31 hp at pto. I am getting ready to buy a rotary cutter but can't decide on 5' or 6'
1. That was 31-hp/PTO in 1955. Even restored you probably have less, especially as it is gas. Your tractor is 2-WD, which is no big deal UNLESS you will mow slopes. On slopes both uphill traction and downhill braking may be safety issues.
2. If you will mow along fence lines you will want a mower a bit wider than your rear tires.
3. If you buy narrower, tractor tires will mash down some verdure before it is cut. If you will be particular about the job you will not want a mower narrower than full width of tires.
4. There is a great variance in weight within 5' and 6' Rotary Cutters, and that weight is cantilevered behind the rear axle. The 'leverage' weight can mount up fast, making the front light. So do not buy too heavy an implement. You do not want the RC to lift either the front wheels or rear wheels off the ground on a slope.
5.
Recommendation:
A. Consider a "Standard Duty" 6' RC but add a good bit of weight to the front of the tractor. Keep the RC blades sharp to reduce the PTO power required to spin the blades.
B. If you will regularly mow well spaced saplings, up to 1-1/2", which is what a standard duty R/C can handle, go with 5'.
I had a well used Standard Duty (40-hp gearbox) King Kutter RC that was an excellent implement.
Why not take time to fill in your T-B-N profile? You will get responses more particular to your questions.
