Rear Blade What size rear blade for my JD3520 for scraping slush?
   / What size rear blade for my JD3520 for scraping slush? #11
If I ran with the rear blade directly behind my tractor - I would need a ten or twelve foot blade - to cover both tires. REMEMBER - whatever angle you decide to run your blade - you will loose considerable, in plowed width. I have the tires set at the widest setting on my Kubota - 80" outside to outside.
You can figure this out using a sheet of graph paper. This is important to know prior to purchase.
When I angle my 96" blade - it will clear a 75" path - on the average. Heavier snow - narrower path. Lighter snow - wider path. I change the angle based upon the type of snow, snow depth & traction.
The idea being - clear the widest possible path. AND - still keep the tractor going in a, more or less, straight line.
   / What size rear blade for my JD3520 for scraping slush? #12
7' for sure
   / What size rear blade for my JD3520 for scraping slush? #13
I have a JD 2025r and use a 6’ rear blade. Your tractor is quite a bit bigger, I’d go with the 7 footer for sure.
EZ loader trailer (A56857)
EZ loader trailer...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
