what size mower, baler
/ what size mower, baler #1
Anonymous Poster
Epic Contributor
I have a kubota B1550 15hp. and 3 ac of hay to mow and bale.
what size mower and baler (if any) works well with this tractor?
thanks
dave
/ what size mower, baler #2
I don't know of anything that will work with only 15 hp. You can try Carver's website. They have some small hay equipment for lower hp units but I still don't think 15 hp would do it.
/ what size mower, baler #3
Maybe a motor run baler but probably still WAYYYYYY too little weight in the tractor to safely stop moving and baler may throw that tractor around quite a bit too. May be able to run a small sicklebar mower though. Just a thought. /forums/images/graemlins/crazy.gif
/ what size mower, baler #5
Super 65 sickle bar mower $950, is designed specifically for your small tractor.
Is that a four foot bar? who makes it? what would shipping cost to Seattle run?
thanks,
dave
/ what size mower, baler #7
What would be a good size sickle bar/brand for a John Deere 4300 ? How much would it cost ?
hey thanks for the baler link! I looked on carver site too but didn't come up with anything.
/ what size mower, baler #10
That mini bailer is $10K+ You can buy a lot hay baled by someone else for $10k
</font><font color="blue" class="small">( I was curious myself so I went to carver's site. They do have a baler for 15-30hp tractors.
Carvers 15-30 hp Baler )</font>
You can buy a used baler for $500-1000, invest $500 in parts.
You can buy a 35hp older tractor for $1500. Add $1000 for an overhaul.
Total investment, well under half of what that new baler costs. And you'll have normal sized bales, a 2nd tractor.
The little tractor will come in handy for raking the hay, maybe cutting hay. It's nice to have 2 tractors for haymaking, lot of swapping & changing implements...
A regular older baler requires about 15 hp to run the baler, & about 15 hp to tow it all around the field. Add 5 more hp to tow a wagon around behind.
More than hp, you need a HEAVY tractor to bale hay. the baler full of hay is pretty heavy, and the plunger going back & forth gives you quite a push/pull effect. Get to a hill, and that baler will shove a light tractor all over the place. CUT's just are designed for baling.
--->Paul
/ what size mower, baler #13
For $11,500 you can purchase a real baler, Vermeer 5400 Rebel. Find you an old 40 HP utility tractor and you'll be making 1200 LB bales. Likely you will be better purchasing a good mower and rake and have the hay custom baled square or round. It's hard to do any more that mow & rake with even a large CUT. Buy the way a Kubota 5030 is not a CUT. A CUT is a smaller frame tractor with 40 HP or less.
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
JOHN DEERE 437E LOG LOADER (A64276)
JOHN DEERE 437E...
2013 FORD F250 (A60460)
2013 FORD F250...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
